Author Topic: EuroRestoMod '70 Challenger  (Read 21379 times)
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
Re: EuroRestoMod '70 Challenger
« Reply #60 on: April 02, 2018 - 01:19:22 PM »
Wow. I had to double check the car at the beginning is the same car.
A lot was hiding under there.
You're doing right!  :2thumbs:
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline YellowThumper
  • I left the snow for this?
« Reply #61 on: May 21, 2018 - 02:45:35 PM »
Very good sir...
Offline Archialfa
« Reply #62 on: December 17, 2018 - 02:37:33 AM »
What to do about this? Can I just sandblast it or I need to take it completely apart?
If I go down sandblasting route is there a possibility that sand might get inside and cause damage later?
1970 Challenger 440 Magnum
Build thread: http://www.cuda-challenger.com/cc/index.php?topic=113902
Offline 70chall440
« Reply #63 on: December 17, 2018 - 12:40:03 PM »
Depends on your desired outcome. If this car is a resto or high end build then blast it as it is with emphasis on the 3rd member. Then disassemble it; have the housing blasted, thoroughly hose it out and replace all the seals. Make sure to rinse out the 3rd member in a parts washer. Put it all back together and paint it.
Current Mopar
Past Mopars
