You need to get the idle around 800 rpm first , at 1400 you are running on the main circuit not the idle circuit , this is the root of the problems you are having , the 484 cam is long duration & will not make much vacuum.
Having a 750 Eddy carb is the worst choice , these carbs are horrible to make work with low engine vacuum , so what is happening is the metering rods are jumping up & flooding the engine so you want the lightest springs available under there for starters . raising the floats from 7/16 to 3/8 will help too . restricting the brass tube on the idle circuit is a must too but very difficult to do , you can solder the tubes closed & redrill much smaller if you have tiny drill bits , I still think you will need to drill the throttle plates as well to get more air flow with the throttle plates closed enough to make the idle circuit work .
