Author Topic: My door hits my front fender.  (Read 2607 times)
Offline 74 challenge
« on: April 27, 2016 - 02:05:03 PM »
I had to put the car away last seasons and was forced to replace the engine.
Got it back on the road to take to the trans shop to throw in the TF2 shift kit suggested by the board and I opened my door this morning and SCRATCH it rips the paint off my door.
What is the easiest way to adjust this? I hate bodywork with a passion.
1-8-4-3-6-5-7-2
Re: My door hits my front fender.
« Reply #1 on: April 27, 2016 - 04:30:50 PM »
Has the door moved?  Hinges worn?  striker loose? If the gaps look good between the door and rear quarter then loosen the fender bolts to slightly move the fender ahead.
Offline anlauto
« Reply #2 on: April 27, 2016 - 05:22:39 PM »
I was thinking worse like the car bent when they put it up on a hoist... :22yikes:
Offline js29no
« Reply #3 on: April 27, 2016 - 05:54:14 PM »
 :iagree: were is the chip above or below the body line? check your gap at the fender.
Offline EbodyMod
  • Will it ever be finished????
« Reply #4 on: April 27, 2016 - 09:27:12 PM »
If the only thing you did was change a motor that sounds like chassis flex...bad juju!
:wavingflag:  Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
Offline 1 Wild R/T
« Reply #5 on: April 27, 2016 - 10:25:30 PM »
Sometimes ahead, sometimes slightly out, sometimes applying upward pressure on the fender while you tighten the bottom bolts....   Pushing up bows the center area out slightly, shimming the bottom moves the bottom 2/3rds out & usually you can loosen the two nuts on the flange ahead of the rocker sill and shift just the lower fender leg if the gap is tight...
« Reply #6 on: April 28, 2016 - 10:00:30 AM »
It's likely the door moved it scratched it right at the body line. I think it has some worm hinges as the door has some up and down play in it.
1-8-4-3-6-5-7-2
« Reply #7 on: April 28, 2016 - 10:08:30 AM »
Just wiggled it I'd call some door play a substantial amount of door play.
1-8-4-3-6-5-7-2
« Reply #8 on: April 28, 2016 - 08:39:17 PM »
I guess you know what you need to do ....
« Reply #9 on: April 29, 2016 - 07:19:56 AM »
Can you just buy new hinges?
1-8-4-3-6-5-7-2
Offline anlauto
« Reply #10 on: April 29, 2016 - 08:26:34 AM »
I never play around with re-bushing old worn hinges anymore. I just buy brand new ones from AMD :2cents:
Offline blown motor
« Reply #11 on: April 29, 2016 - 08:48:14 AM »
I got a pin and bushing set from Napa a couple years ago. I think it was around $12. Works great for a driver.
Offline 1 Wild R/T
« Reply #12 on: April 29, 2016 - 10:37:46 AM »
I'd rather add bronze bushings... Bronze has always been an excellent choice for long life in this sort of application Vs replacing the original steel hinge which a AMD (Chinese) knock-off...
It's great that so many parts are now reproduced if you need them, in the case of hinges you really don't... :2cents:
