Author Topic: DakotaDigital direct fit gauges  (Read 1643 times)
Offline roadman5312
« on: May 01, 2016 - 10:59:11 AM »
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: DakotaDigital direct fit gauges
« Reply #1 on: May 01, 2016 - 11:10:38 AM »
I would love to put a set of these in the Charger, but a buddy here bought his '70 with aftermarket gauges and is having all kinds of wiring and power issues.  Would you have to upgrade your entire wiring harness and alternator to run a set of these?
Offline GreenFish
« Reply #2 on: May 01, 2016 - 07:13:54 PM »
Go to the website and check it out. The installation instructions are on there. You are basically putting in a new harness for the new gauges that run off of a processor. all electronic sensors etc. It actually looks pretty simple to install.
Offline crash340
« Reply #3 on: May 01, 2016 - 07:19:10 PM »
I wonder if there is ever a time they might be discounted a little, nice set up, really like it and I might abandon my proposed std gauge set mods I was planning, would just need a rallye bezel and three switch light bezel and good to go😬
Greg
73 Cuda
Brisbane, Australia
« Reply #4 on: May 02, 2016 - 08:16:25 AM »
Simple except it is important for people to realize this is not plug and play. You can't just buy the cluster and find all the wires you need already in your existing dash. All the sensors on your car originally used one wire back to the dash. Body being the other 'wire'. The new sensors you need to install for this dash to function uses multiple wires and they have to be brought through the firewall. ie drilling holes.
Offline GreenFish
« Reply #5 on: May 02, 2016 - 04:31:30 PM »
yeah, I agree, most of my gauges are already aftermarket at this point anyhow so I suppose "simple" is all relative
« Reply #6 on: May 03, 2016 - 11:33:29 PM »
Believe there would be negligible power consumption difference.
