Author Topic: 70/71 challenger fender mounted signal measurement request  (Read 1775 times)
Offline manycj
« on: May 03, 2016 - 08:11:54 AM »
I really need the measurement in the picture below taken from a 70/71 Challenger. The previous posts I found on this forum do not give the correct measurement from front to back. Probably because it came from a 73. All I need is for someone to take a tape measure and measure from the front edge (less headlight bezel) to the front of the turn signal indicator. It has to be a 1970/71 style (no screw on the top). Hole location measurements would be better, but still has to come from a 70/71 Challenger. Just let me know how you took the measurement.
thanks
Chris
Offline anlauto
Re: 70/71 challenger fender mounted signal measurement request
« Reply #1 on: May 03, 2016 - 08:17:12 AM »
If you "eye ball it" based on that picture, I don't think anybody will notice if you're an 1/8 inch out  :2cents:
Offline manycj
« Reply #2 on: May 03, 2016 - 08:25:54 AM »
I'm picky.....
Offline FCC
  • 1973 Dodge Challenger 340
« Reply #3 on: May 03, 2016 - 09:36:37 AM »
Not that anybody will notice but you will know!  And that makes a big difference most of the time.  At least it would be for me.   :bigsmile:
I can get the measurements off my car but mine is a 73 with factory fender mounted signals. Would it be the same???
Offline anlauto
« Reply #4 on: May 03, 2016 - 10:12:18 AM »
I'm picky.....
I doubt the factory was picky :2cents:
Offline manycj
« Reply #5 on: May 03, 2016 - 12:19:57 PM »
I would suspect that they are, but not 100% sure.  If you can give me a measurement from the side that faces the driver (lens side) then I can be pretty sure that the viewing angle of the light will be the same.
Chris
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #6 on: May 03, 2016 - 06:17:31 PM »
I believe it  is 7 1/4" from fender to front of signal fixture
72rtchallenger
what happens in the garage
stays in the garage
Offline FCC
« Reply #7 on: May 03, 2016 - 08:19:38 PM »
Mine measured @ 7.75" from fender to front of signal fixture.
Offline manycj
« Reply #8 on: May 04, 2016 - 07:58:41 AM »
Just to be clear, when you say "front" to do mean A or B ?
  • 72 to 70 clone
    • cardomain
« Reply #9 on: May 04, 2016 - 06:44:23 PM »
I meant A ,,and my car is a 72 but had the 70 to 71 style signals ,, and that is how mine measured out .
72rtchallenger
stays in the garage
Offline manycj
« Reply #10 on: May 05, 2016 - 08:20:07 AM »
Great, thanks for your help.  I didn't want to drill holes in my fenders  and find out I was wrong.
Chris
