Author Topic: Wheel Seal Orientation - Front Axle  (Read 4082 times)
Offline Glow Worm
« on: May 04, 2016 - 08:46:43 PM »
 :working:
I had a noise in the front of my car.  Thinking it was probably a bad wheel bearing I popped the calipers off, took off the rotors, removed bearings, seals, and races. Went to the local parts stores and got the parts I needed.
I'm embarrassed to say (now) I can't remember how the seals go in.  The seals I got are Timken's and have the rubber "boot" on one side.
Does that boot go in the hub "toward" the bearing, or does it stick out and go into the recess on the spindle?
The car is a 73 Cuda 340.
Thanks!
« Last Edit: May 04, 2016 - 08:48:26 PM by Glow Worm »
"If I had all the money I've spent on cars . . . I'd spend it on cars."
Re: Wheel Seal Orientation - Front Axle
« Reply #1 on: May 04, 2016 - 09:07:50 PM »
side with spring goes into disk toward the bearing  ....clear as mud?
Offline 734406pk
  • Andy
« Reply #2 on: May 04, 2016 - 09:09:36 PM »
Usually the spring side goes towards the grease, but i'm not sure by your description. Some Mopar seals are hydro-dynamic and have in integral dust seal. Can you post a pic or a part number?
Offline 1 Wild R/T
« Reply #3 on: May 04, 2016 - 09:40:49 PM »
The "boot" faces out when looking at the back of the rotor....   Before tapping it in, make sure it fits the seal surface on the spindle...
Offline Glow Worm
« Reply #4 on: May 04, 2016 - 10:13:26 PM »
Timken 5121
« Reply #5 on: May 04, 2016 - 10:40:15 PM »
Timken 5121
Quite sure mine didn't have a large protrusion like that...doesn't mean it's wrong just a different style
 From the few pics I've seen of that style it seems the protrusion of rubber (pic. top) would go toward the axle
mine looked more like these , had the spring on the inside
Offline jimynick
« Reply #6 on: May 04, 2016 - 10:52:32 PM »
Let your common sense take over. There's no way to drive that seal in on the lip side- so, put it in the rotor with the  smooth, steel back showing up and drive it in, on said back. Easy, eh?  :cheers:
« Reply #7 on: May 04, 2016 - 11:00:28 PM »
Brilliant!  :woo:
Offline 1 Wild R/T
« Reply #8 on: May 04, 2016 - 11:36:12 PM »
EXCEPT YOUR WRONG...  70-72 have a flat metal face, 73-74 have the seal shown above which has a normal seal backside and a protruding lip on the outside...
Offline jimynick
« Reply #9 on: May 04, 2016 - 11:47:41 PM »
OK, sure. It's too late to argue, so drive it in on the lip. Good luck
Offline 1 Wild R/T
« Reply #10 on: May 05, 2016 - 12:24:27 AM »
The way to do it is to tap the metal flange outside the protruding lip.... Personally I use a an old bearing race as a driver...  If you think I'm wrong go get a Timken 5121 & have a look at it, thy aren't like most seals... Hell I worked for a bearing company, I think I might know what I'm talking about...
« Last Edit: May 05, 2016 - 12:26:51 AM by 1 Wild R/T »
Offline 73_Cuda_4_Me
« Reply #11 on: May 05, 2016 - 06:26:37 AM »
The dust boot (protruding lip) goes outward, and rides on the larger diameter of the spindle base. They are a bit of a pain to install, but I used a large socket to press mine in...
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline blown motor
« Reply #12 on: May 05, 2016 - 07:49:17 AM »
Is the 14708 seal the right one for a 74 Challenger? Napa gave me 19500.  :clueless:
Offline 734406pk
  • Andy
« Reply #13 on: May 05, 2016 - 08:27:43 AM »
 :iagree: That rubber protrusion is the dust boot. It rides on the spindle to help seal out dirt from the bearings. Faces outwards, it was an improved design to the earlier type seal, and a pain to install. You will need to find a driver that doesn't crush the dust seal. A thinwall socket or a piece of pipe ground out with a Dremel etc.
« Last Edit: May 05, 2016 - 09:17:58 AM by Bullitt- »
