Author Topic: help carb or vacuum issue maybe.  (Read 1723 times)
Offline cudasteve72
« on: May 05, 2016 - 05:22:42 PM »
So I'm not totally sure but as I'm driving and let off the gas and push in the clutch the rpms go up to around 3000.  It kind of starts to go down when I hit the brakes (power) but not to where it should idle.  I have a proform 850 mechanical secondary carb that only has one manifold vacuum port for brakes and pcv, nothing on intake all seem to be connected or plugged.  Any ideas
1972 Cuda Custom 70 clone  416 stroker 481/531 hp/
2006 Grand Cherokee SRT8 (daily)
1970 Challenger convertible 340 (Dad's)
1967 Dart gt slant six all original 40,000 miles driver but needs restoration (Brother's)
2011 Jeep Grand Cherokee (wife's)
Offline 734406pk
  • Andy
Re: help carb or vacuum issue maybe.
« Reply #1 on: May 05, 2016 - 07:58:23 PM »
How does your engine idle in park/neutral? Do you have the correct throttle return spring?
« Reply #2 on: May 05, 2016 - 08:55:57 PM »
Lots of ideas  , wish I was there !
 any binding in throttle cable , linkage or kick down linkage , strong enough springs for both kicck down & throttle , carb snaps closed when it is opened ?
 dist advance weight springs OK & advance plate moves freely , vacumm advance disconnected ?
Offline cudasteve72
« Reply #3 on: May 05, 2016 - 10:14:36 PM »
I have a rev n nator, they recommend not running the vacuum advance.  The throttle does snap closed.  Just sitting in neutral in the garage it idels fine, maybe a little rich but smooth and normal. The only issue with the cable may be the travel distance but it is smooth too.
Offline 734406pk
  • Andy
« Reply #4 on: May 05, 2016 - 10:20:46 PM »
A frayed throttle cable can easily cause your issue. I would recommend changing this cable asap as it can be dangerous to drive this vehicle if the cable is sticking. If the problem persists we can move on from there.
Offline YellowThumper
  • I left the snow for this?
« Reply #5 on: May 06, 2016 - 10:26:04 AM »
X2 on changing your throttle cable if it is even frayed a little.
Learned by error on mine. Had car up to about 115 with throttle wide open before I just had to turn key off.
Offline 734406pk
  • Andy
« Reply #6 on: May 07, 2016 - 06:42:20 PM »
What is the issue with travel? Does the cable allow the throttle plates to return to the idle stop?
Offline cudasteve72
« Reply #7 on: May 09, 2016 - 02:39:33 PM »
Im not. Sure if it goes wide open it closes good though.
Offline 734406pk
  • Andy
« Reply #8 on: May 09, 2016 - 08:35:59 PM »
If you rev the engine from idle to say 3000 rpm, and you let off the gas peddle, does the engine return to its idle rpm consistently? Or do you find it hanging up?
