Author Topic: cuda fuel cap and fuel line routing  (Read 5608 times)
Offline fc7vw9
Re: cuda fuel cap and fuel line routing
« Reply #15 on: May 16, 2016 - 02:16:26 PM »
Here are some pictures of my 71 I'm restoring.
Sent from my XT1080 using Tapatalk
Offline fc7vw9
« Reply #16 on: May 16, 2016 - 02:18:47 PM »
Inside of trunk.
Offline culp71
« Reply #17 on: May 16, 2016 - 02:59:48 PM »
ok ,awesome thanks fc7vw9.
that clears up a bunch of stuff :thumbsup:...
so then does yours have a vented cap?
and could you get a few more pics of in the trunk where it
looks like a bracket that is welded to inner fender that the tube straps to...?
I found "MF553A - 1970-72 Barracuda Ecs Vapor Line-5/16"- Original
Material from classic industries", I believe this is the correct line for this
5th vent line that hooks to the valve cover breather cap, correct if wrong.
« Last Edit: May 16, 2016 - 03:43:38 PM by culp71 »
Offline fc7vw9
« Reply #18 on: May 16, 2016 - 05:01:51 PM »
I purchased mine from fine lines. See picture for part number. It is a two piece set one long one from front to back and one short one up the wheel well with a short piece of hose connecting the two. It is 5/16 and at the rear connects to the front tube on vapor tube. 71s also use double tube straps where both 5/16 fuel supply tube and 5/16 vapor line are in the strap and mounted to the under carriage. Fuel cap should read pressure/ vacuum. Because it is a "sealed" system either condition may be present when removing cap.
Offline fc7vw9
« Reply #19 on: May 16, 2016 - 05:04:55 PM »
Vapor tube is stapped to bracket with a large keystone clamp. Sorry pictures are kinda blurry, time for a new phone. Hope these help.
Ron
Offline culp71
Re: cuda fuel cap and fuel line routing/ecs vapor tube bracket
« Reply #20 on: May 25, 2016 - 01:46:19 PM »
anyone know of where one can find the bracket that appears to be welded to inner, outer fender to mount the vapor tube separator to?
« Last Edit: May 25, 2016 - 03:02:26 PM by culp71 »
Offline anlauto
« Reply #21 on: May 25, 2016 - 02:58:53 PM »
On an old wheel well outer :2cents: Don't believe they're reproduced.
Offline culp71
« Reply #22 on: May 25, 2016 - 03:05:10 PM »
i could easily make one , does some one have decent picture of one?
Offline AARTA340
« Reply #23 on: May 25, 2016 - 04:22:15 PM »
Hi Jason,  I am sure I have one and you can have it. I will not be back home till mid June though. Keep this in mind if you can't find one.
