Author Topic: Spraying paint at home advice?  (Read 7619 times)
Offline shadango
Re: Spraying paint at home advice?
« Reply #30 on: June 27, 2016 - 08:54:06 AM »
Well, at least I tried.
I have spent weeks of spare time on the hood/scoop project.  Got it to the point of being ready for color coat saturday morning.
Got up with the roosters and sprayed it.
Thought it laid out great.
Then I realized it hadn't.
The first foor of the hood i sprayed is PERFECT..literally perfect.......then it goes to hell.
Had two passes that got "sandy".......and even though I laid on two coats in different directions, I still have some tiger striping.
And the scoop looks like crap.....like it has no color on it at all, and I KNOW I watched the color lay on it when I sprayed it on.
Not sure what the problem was.....weather? Humidity? technique? mix? spray gun?  air? quality of air?
Trying to decide what to do...
....buy more paint ($70 at least) and try again is the cheapest route but whats the point without knowing what I did wrong.....
....sand it back down and farm out the final color spray to a real painter......$$$
....sand it down some and get it wrapped.....
I am disappointed....I really thought I could do it.....    :pullinghair: :banghead:
« Reply #31 on: June 27, 2016 - 09:48:17 AM »
You can. You laid down perfect paint at the beginning right? So you CAN do it. Maybe it was the mix in the cup, I don't know but if it were me I would try to find out what changed, correct it, and try again.
Offline shadango
« Reply #32 on: June 27, 2016 - 10:29:39 AM »
I had similar issues with the primer coats and was trying to solve the issue each coat..
Obviously I didn't find the issue.
Offline Rdchallenger12
« Reply #33 on: June 27, 2016 - 11:14:10 AM »
And this to me is what I am terrified the most about doing my car having never painted one... Keep going back and forth on giving it a shot or forking out the $$$
Offline shadango
« Reply #34 on: June 27, 2016 - 11:27:39 AM »
Exactly.
It's like gambling......will the next hand be the winner or the one after that?  Lol
Offline turbostang7
« Reply #35 on: June 27, 2016 - 12:07:11 PM »
I saw on another thread that you were using a Harbor Freight gun, I have never had luck with those. It always tiger striped no matter what I set it at.
you could get a really nice fan pattern on the test panel but as soon as you walked over to the actual project it was off again. Could be your issue.
1970 Barracuda project in the making!
Offline shadango
« Reply #36 on: June 27, 2016 - 12:53:36 PM »
Yeah I was wondering too.....though they say 'A poor craftsman blames the tool"...LOL.....
Still, spend $100 more for paint and another $150 for a new (non harbor freight) gun to try again?
 :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
Offline turbostang7
« Reply #37 on: June 27, 2016 - 01:02:09 PM »
at that point you are almost to the cost of a professional spraying just a hood.
Offline rhamson
« Reply #38 on: June 27, 2016 - 01:35:58 PM »
It sounds like an overlap problem to me. I try to adjust the volume to a misting fan while half lapping the pass. The first car I painted tiger striped and I came back over it in a closer pattern which solved the problem. The HVLP guns will reduce the over spray while the siphon cup sprayers will shoot more paint in a smaller section. Even coats are based on overlaps.
