Author Topic: Need advice on what to do with unknown paint  (Read 2179 times)
Offline Loa
« on: May 07, 2016 - 09:08:32 PM »
Hello,
Just got my new Mopar and it has a really bad paint job. Problem is, I won't have the budget to properly repaint it until next year. The car was originally white but has been repainted red with a single stage paint. The paint is weak (gets on the towel when cleaning with degreaser) and is already cracking/peeling in many places.
I was planning on polishing it lightly, fixing the rust spots with primer + paint then hitting the entire car with a coat of clear (all using spray cans). Not looking for stunning results, only to protect it until next year.
Is that a good idea?
Thanks.
Offline jimynick
Re: Need advice on what to do with unknown paint
« Reply #1 on: May 08, 2016 - 11:19:22 PM »
In my opinion, the short answer would be- no. You can put lipstick on a pig, but it's still a pig and trying to salvage what you describe would be way more work than it's worth. Then consider the fun to remove it eventually after having cleared it. Paint jobs have gotten stupidly expensive and I get where you're coming from, though. Good luck.  :cheers:
Offline Loa
« Reply #2 on: May 09, 2016 - 10:31:29 AM »
Hello,
Thanks for the advice. I now have a new question: given that this car won't be protected from the elements, should I at least take care of the rust spots? Just sand them down to metal, prime and spray a single stage paint on them?
Thanks
Offline 70chall440
« Reply #3 on: May 09, 2016 - 12:03:10 PM »
For now, feather out the chips and such, clean it really well and shoot some duplicolor (O'Reillys/Schucks) on it to protect it until you can afford a real paint job.
Current Mopar
Past Mopars
Offline EbodyMod
  • Will it ever be finished????
« Reply #4 on: May 09, 2016 - 07:23:56 PM »
 :iagree: primer spots are way cooler than more rust!!
:wavingflag:  Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
Offline Loa
« Reply #5 on: May 10, 2016 - 10:00:26 AM »
Thanks for the advice! I'll start working on it as soon as it gets warm enough outside... :-)
Offline js29no
« Reply #6 on: May 10, 2016 - 12:56:01 PM »
Primer is porous, use rattle can single stage acrylic enamel so it doesn't rust. A parts store that mixes paint some times will have the set up to mix A pint and insert it into A spray can. :2cents:
Offline Loa
« Reply #7 on: May 10, 2016 - 05:23:56 PM »
Yeah, I was going to paint over the primer spots... They are cooler than rust, but not as much as decently matched paint spots...   :-)
Offline shadango
« Reply #8 on: May 12, 2016 - 10:24:07 AM »
What about a wrap? I know it sounds goofy but from a price standpoint maybe ?
Sent from my SM-N910T3 using Tapatalk
Offline YellowThumper
  • I left the snow for this?
« Reply #9 on: May 12, 2016 - 10:45:29 AM »
Wraps are a good option. Quality ones will last for several years.
Still have to address rusting spots prior.
Offline mopar jack
« Reply #10 on: May 12, 2016 - 11:27:58 AM »
If you sand the rust spots to bare metal I would use a metal etch solution to stop the rust then prime and seal.
Offline Loa
« Reply #11 on: May 12, 2016 - 07:44:51 PM »
Hello,
Not really into wraps, and I'm going to invest in good paint next year anyway.
@mopar jack: are these etching products really worth the money? Isn't priming enough to stop the rust?
Thanks for the info.
Offline mopar jack
« Reply #12 on: May 12, 2016 - 09:14:25 PM »
The etching solution is a phosphoric acid and it converts the surface rust from iron oxide to iron phosphate making it very stable.
Offline Loa
« Reply #13 on: May 13, 2016 - 08:19:47 AM »
Thanks! I'll get a can before priming!
Edit: given that I already have my regular primer, can I buy a can of phosphoric acid meant for cleaning bathrooms? (3M makes one)
« Last Edit: May 13, 2016 - 08:24:48 AM by Loa »
Offline mopar jack
« Reply #14 on: May 13, 2016 - 12:18:46 PM »
Don't know about bathroom cleaner. I just buy a quart from my automotive paint supply. It goes a long way, you wipe it on with a rag and rinse it off with water then dry. Make sure you use proper protective equipment.
