Author Topic: Trying to reduce bump steer. Anyone try these  (Read 1784 times)
Re: Trying to reduce bump steer. Anyone try these
« Reply #1 on: May 08, 2016 - 10:49:36 AM »
I believe Brad is using something similar
« Reply #2 on: May 08, 2016 - 11:51:10 AM »
Any clearance issues with the wheel?
« Reply #3 on: May 08, 2016 - 02:53:42 PM »
You could buy all those pieces yourself from Allstar and save  at least half?
I used this . https://www.howeracing.com/p-7449-howe-quick-bump-tie-rod-ends.aspx
Offline rt green
  • third string oil changer
« Reply #4 on: May 09, 2016 - 08:09:20 AM »
just make sure your centerlink is level
Offline leanburn
« Reply #5 on: May 09, 2016 - 08:46:53 AM »
Ok, so mine is not level, I haven't gotten it on the lift to measure it but it's definately out 1/2" or more. So how does a person level it ?
« Reply #6 on: May 09, 2016 - 06:20:50 PM »
Offline leanburn
« Reply #7 on: May 09, 2016 - 09:56:38 PM »
Seems pretty straight forward, I assume I would have to make shims?
Offline 1 Wild R/T
« Reply #8 on: May 10, 2016 - 11:09:43 AM »
One thing that never gets mentioned... If you file the bolt hole to correct the drag link side to side you've created a point of motion, it will find a way to loosen & move... So to fix it when you are assembling the idler put a semi-large flat washer on before the nut & when you have the drag link level & things are tight put a few tack weld on the washer to the K frame...
No, standard alignment shims work just fine...
« Last Edit: May 10, 2016 - 11:11:47 AM by 1 Wild R/T »
