Author Topic: EDP Coating on New Panels  (Read 2229 times)
Offline glovemeister
« on: May 12, 2016 - 09:07:02 PM »
I am curious as to if I should remove it to bare steel, scuff it with red scotchbrite and leave it  or just wash it down and leave it?  On the interior surfaces of the panels I am going to leave it and top coat with epoxy.  I am aware of methods to test if the primer is truly EDP or cheap lacquer primer, so I will do that first.
Thanks
1971 Challenger RT
Offline jimynick
Re: EDP Coating on New Panels
« Reply #1 on: May 12, 2016 - 09:27:27 PM »
All the AMD panels that I've used have a very good, tight and durable coating and I've left it on and worked on top of it. It doesn't grind off easily and I'm satisfied that it'll go the distance. Hope that give at least one opinion.
Offline Rich G
« Reply #2 on: May 12, 2016 - 10:30:24 PM »
I was told by a PPG rep to leave it on. Get a rag with some lacquer thinner on it and rub it on the panel. If it comes off its no good. The good EDP won't come off.
Offline js29no
« Reply #3 on: May 13, 2016 - 09:37:26 AM »
:iagree: :2cents:
« Reply #4 on: May 13, 2016 - 01:35:09 PM »
Awesome thanks for the info. I am at the stage where I am a little  tired of trying to get to bare metal, so if I can leave a panel with EDP that makes me happy!
1971 Challenger RT
« Reply #5 on: May 13, 2016 - 01:35:31 PM »
Thanks for the information.
1971 Challenger RT
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #6 on: May 13, 2016 - 05:16:24 PM »
Take it off. If not you might be in for a surprise down the road.Epoxy Primer is designed to be applied to bare metal only. I do this on every car I do.
Offline AARTA340
« Reply #7 on: May 13, 2016 - 05:23:01 PM »
I had been wondering about the factory EDP as well. I was just beginning to feel comfortable with leaving it on, but now, we need some paint pros to put this one to rest.  :clueless: :clueless: :dunno: :dunno:
« Reply #8 on: May 15, 2016 - 05:42:53 PM »
I appreciate the advice everyone.
Now specifically on the back side of a panel, in the spot weld area.
Should I remove it to bare steel and then weld through primer it, leave edp and hit it with weld through primer on that flange area?
My concern is if EDP bubbles then it removes the weld through coating I am trying to utilize.
Spot welds will of course be free of primer as they are supposed to be.
1971 Challenger RT
Offline lulurocks
« Reply #9 on: May 15, 2016 - 07:07:58 PM »
Remove it an 1" back from  any welds  and prime it with high quality weld-thru primer  , like you thought.
 :2cents:
Offline js29no
« Reply #10 on: May 16, 2016 - 09:57:17 AM »
 :2cents:  :iagree:
