Author Topic: Toyota Yaris question - Oil pan gasket or no gasket?  (Read 804 times)
Offline 74 challenge
« on: May 13, 2016 - 10:32:58 AM »
I am prepping a Toyota yaris for a cross Canada drive however we have been told that the dented Oil pan will not pass a BC inspection.
I bought a new pan and gasket but the world seems to be mixed on how to install it.
I have three methods - does anyone know which one is correct?
1. No gasket just RTV
2. Gasket installed with a thin layer of RTV on the gasket
3. Gasket with spray Adhesive
the gasket is a fel pro unit it looks to have some blue rtv sealant already built in but it does not go around the bolt holes. The oil pan is brand new.
1-8-4-3-6-5-7-2
Re: Toyota Yaris question - Oil pan gasket or no gasket?
« Reply #1 on: May 13, 2016 - 10:35:39 AM »
If you use the gasket I would follow the inluded instructions .
 a bead of Right Stuff sealant with no gasket would seal it up too as long as the sealant is carefully applied
« Reply #2 on: May 13, 2016 - 10:39:50 AM »
I thought the gaskets would come with instructions but it's just the gasket in the box. I thought a quick google search would find the answer.
1-8-4-3-6-5-7-2
« Reply #3 on: May 13, 2016 - 10:56:44 AM »
I believe using rtv on the gasket is a good way to get the gasket to fail. Use one or the other, but not both.
My personal preference would be the rtv without a gasket.
« Reply #4 on: May 13, 2016 - 11:39:16 AM »
I was thinking this route myself.
1-8-4-3-6-5-7-2
Offline moparmike70
« Reply #5 on: May 13, 2016 - 01:37:59 PM »
I work for Toyota and it does not come with a gasket from the factory, just RTV
