Author Topic: replacing Trunk extenisons  (Read 1682 times)
Offline theblurr
« on: May 16, 2016 - 11:17:37 AM »
Hi,
I going to replace my 74 Challenger trunk floor extensions, I'm looking at AMD and Goodmark which do you recommend I use?
Thanks Brent
'I will live until I die,
Then I will live forever.'
                    Brent
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: replacing Trunk extenisons
« Reply #1 on: May 16, 2016 - 11:54:11 AM »
haven't heard of any issues from either from customers. We have used both.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline jimynick
« Reply #2 on: May 16, 2016 - 10:54:49 PM »
In my 74 Challenger, I used the AMD ones that I got from Dave. They fit OK. Make sure you mount the rear valance and check the fit before you final weld them in, though. The only problem is that the rt one has the hole for the emissions tube they used in the early years. I'm just going to make a cover and screw it on in the supplied holes. Hope that helps.  :cheers:
Offline Rdchallenger12
« Reply #3 on: May 18, 2016 - 01:29:03 PM »
I too am replacing my inner trunk extension on my driver's side. What would you suggest is the best and safest way to remove it without effecting a outer rear fender? Mine is only rusted on the bottom so I was thinking of just cutting about an inch above the rust where it is solid and trace the new one then attaching it.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #4 on: May 18, 2016 - 05:26:30 PM »
Depends on how clean of a job you want and if you want to weld it in or use panel Bond ?? the wheel lip and bottom edge are your problem areas that will affect the Quarter panel.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline anlauto
« Reply #5 on: May 18, 2016 - 05:38:06 PM »
I recommend AMD :2thumbs:
Offline GoodysGotaCuda
« Reply #6 on: May 18, 2016 - 06:28:37 PM »
I used either Goodmark or Sherman [same parts] from Rock Auto. Seemed fine, but I am not going for a 100% accurate resto either.
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #7 on: May 18, 2016 - 08:27:09 PM »
 :woohoo:
Was planning on using panel bond, since it will be out of site and also have under coating in it, appearance isn't of the biggest concern.
Offline theblurr
« Reply #8 on: May 20, 2016 - 05:38:48 PM »
Thanks For all the replies. Such a Great site!!
Brent
                    Brent
