Author Topic: gauges not working.......  (Read 1198 times)
Offline Belltone85
  • 1973 Dodge Challenger 360 Crate Motor, Slap Stick
« on: June 16, 2005 - 09:13:31 PM »
the guages used to work but now they don't work i dropped in a new motor and tranny but they did work for a few days after but now nothing.... any suggestions?
Re: gauges not working.......
« Reply #1 on: June 17, 2005 - 12:01:11 AM »
probably the voltage reg fo rthe dash , it pulses the current & limits it to 5 volts
Offline Challenger6pak
« Reply #2 on: June 18, 2005 - 05:12:31 PM »
If the guages ran real high and then quit you could have had a voltage limiter go out in the cluster.
Offline Belltone85
« Reply #3 on: June 23, 2005 - 12:23:03 AM »
i should actually re-phrase that... the speedo and the tach work just not properly (they are not accurate at all, speedo bounces around and the tach it will says 2,000 when its just idling) and the alt meter works but the gas, oil pressure, and temp guages do not work at all... if it is the voltage reg where is it located? and how do you test?
« Reply #4 on: June 23, 2005 - 03:26:48 AM »
It has to be the voltage regulator. It connects to the 3 gauges that aren't working for you. It's located right on the back of the gauges. You'll see a wire coming from it, linking those 3 gauges together.
Offline Belltone85
« Reply #5 on: June 23, 2005 - 06:33:27 PM »
ok ya i found it now, can it be fixed or do you have to get a new one? where do you get a new one?
« Reply #6 on: June 24, 2005 - 01:22:32 AM »
I think Standard has new ones should be available from any parts store
 The Tach needs to send away to a guage repair compant to have it upgraded to new electronics to work correctly , the speedo may as well go to to be repaird but check the cable first to be sure it is not causing the bouncing , the inner speedo cable can be removed & lubricated
Offline 70RT440SHAKER
    • Challenger R/T
« Reply #7 on: June 26, 2005 - 01:55:23 PM »
