Author Topic: 340 Question  (Read 1895 times)
Offline daveh
340 Question
« on: May 19, 2016 - 03:35:21 PM »
Hey guys,
I have a 1969, 340 I think it's internally balanced can you all please confirm that for me?  Thanks
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: 340 Question
« Reply #1 on: May 19, 2016 - 04:24:41 PM »
Can you see the flywheel?  Does it have a big notch out of it? Then external.
Can you see the crankshaft?  Does it have weights on it?  Then internal.
Re: 340 Question
« Reply #2 on: May 19, 2016 - 11:00:36 PM »
69 should have a Steel crank all of them did .
 But it has been 47 years I highly doubt anyone would install a cast 340 crank in an earlier 340 but strange things do happen , if it needed a donor crank at some point you could use a steel 318 crank which is much more common & add weight to balance for the 340 .
 SO assuming it runs & doesn;t vibrate it is balanced & it should have a 1" thick damper on the front , cast rank used a thicker damper clearly marked for cast crank on the front face
