Author Topic: Steering column question! Please help!  (Read 4816 times)
Offline Wadmin1021
« on: May 21, 2016 - 02:46:16 PM »
The hubby and I are working on rebuilding the steering column for our 1971 Cuda. We want manual steering and will be having our steering box rebuilt for 24:1 ratio. During tear-down of existing steering column (that came with the car) we noticed that the coupler is too small to fit onto the steering box. Couple questions: 1) Will our current steering shaft work for manual steering set up??  2) We believe coupler is for power steering. Is this correct? Please see pics below:
Full length shaft:
Collapsed shaft:
Coupler doesn't fit onto steering box:
https://youtu.be/OEKt5K71CDM
A couple that plays together, stays together!
'71 Plymouth 'Cuda named Claudia w/ 440 4-barrel and TF AT
Offline JS27N0B
  • Member since Jan 28th 2003.
Re: Steering column question! Please help!
« Reply #1 on: May 21, 2016 - 03:55:14 PM »
Manual steering and power steering columns have a different length shaft. You will have to find an inner shaft for a manual, or at one time someone made a short adapter piece to go from power to manual steering.
2013 Tige' RZR 343hp
Offline Wadmin1021
« Reply #2 on: May 21, 2016 - 07:40:26 PM »
So what do we have? A manual or power steering shaft? And what are the measurements supposed to be on those? Also, what about the coupler I asked about?
Offline Finoke
« Reply #3 on: May 21, 2016 - 09:30:12 PM »
Its been a while since I did a conversion. But the coupling is called a pot coupling. They are different between manual and power with the spline opening. The steering shafts are also different lengths between manual and power. There is an extension that is sold if you need to lengthen your shaft or you can buy a used steering column.
http://www.manciniracing.com/mopemastad.html
I believe the piece above will fit on the manual box then your power steering pot coupler slips on the male spline. Then you can use your power steering shaft which is to short without this extension.
« Last Edit: May 21, 2016 - 09:40:16 PM by Finoke »
Offline Wadmin1021
« Reply #4 on: May 21, 2016 - 09:38:00 PM »
Can anyone tell me what we have? Power steering shaft or manual steering shaft?
Offline anlauto
« Reply #5 on: May 21, 2016 - 09:51:22 PM »
The coupler you have is power steering.
If the shaft you have is too short, it's for power steering too.
You can keep the restored steering column and just change the shaft and coupler.
Offline Wadmin1021
« Reply #6 on: May 21, 2016 - 10:00:53 PM »
Thank you - we thought so about the coupler but wasn't sure. We don't know if the shaft is too short. We bought the car in pieces basically and it's never been installed. Our car currently has no motor in it or any interior. How do we tell if it's for power or manual? Are there measurements for the two? We don't want to spend the money on anything when we don't know what we have?!
« Reply #7 on: May 21, 2016 - 11:07:49 PM »
Sorry I do not have the shaft lenghts here to reference for you but Alan or Cody should have them .
 Really it doesn't matter as either shaft is usable , if you have the power steering shaft the adapter will correct to length & spline for manual , if it is for manual you are good to go .
 Don't buy anything right away anyway
Offline Wadmin1021
« Reply #8 on: May 21, 2016 - 11:30:54 PM »
How do I get a hold of Alan or Cody?
Offline Lbs
« Reply #9 on: May 21, 2016 - 11:34:20 PM »
Not trying to hijack this thread but what I'm reading here is making me a little nervous. My 73 Cuda had manual steering and my son hit a curb and broke the steering box. So I took the opportunity to switch it over to power steering. I went to a junkyard and got a power steering box and pump with mounting brackets. I didn't change the steering column or the coupler and it seems it all went together well. The only thing I haven't seen mentioned here that mine had, is a collapsible steering column. I'm a little worried mine might not be safe.........any thoughts?
Sent from my iPad using Tapatalk
« Reply #10 on: May 21, 2016 - 11:37:27 PM »
Alan is Anlauto in this thread , search cuda Cody on this site you can usually PM them
Offline Wadmin1021
« Reply #11 on: May 21, 2016 - 11:40:41 PM »
Tried PM but says inbox is full!
« Reply #12 on: May 21, 2016 - 11:40:53 PM »
 Well the collapsable shaft is damaged so the inner shaft can slide up inside the outer shaft , this could disconnect the steering shaft form the coupler , there is a tiny press pin in the side of the coupler that will prevent this from happening & allowing the shoes to slide up out of the coupler so you need to be sure it is in there .
« Reply #13 on: May 21, 2016 - 11:42:20 PM »
[/quote
 With ALan & maybe Cody too there is a small envelope under there ICON when they post click on that & It will send an email drirect to them
Offline Wadmin1021
« Reply #14 on: May 21, 2016 - 11:47:55 PM »
Got it! Thanks Chryco! Email sent!
