Author Topic: Backfire on acceleration  (Read 4478 times)
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Backfire on acceleration
« Reply #15 on: May 24, 2016 - 11:11:32 AM »
Thanks Andy and Bob.  I was told the "old style" coil I have is not meant for the RTR distributor due to potential high voltage spikes, so the modular style should be here Thursday.  I double checked the wires and firing order and they are all good.  I'm swapping the 4 speed in my buddies shop starting tomorrow and we will check the timing and accel pump then.
Offline jhaag
« Reply #16 on: May 24, 2016 - 08:51:07 PM »
was it ever determined if it is a backfire thru carb, or exhaust? 2 entirely different scenarios as CP pointed out.
love 70 Challengers
Offline 734406pk
  • Andy
« Reply #17 on: May 24, 2016 - 09:03:26 PM »
Good luck and keep us posted!
Offline dfrazz
« Reply #18 on: May 26, 2016 - 08:12:40 AM »
Quick update - timing was perfect but when I was checking the wires #5 boot was melted through.  I have a new one from Rich at Firecore on the way along with some titanium sleeves.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #19 on: May 26, 2016 - 11:37:17 AM »
So I guess the wire was resting on the header/manifold?
Offline GreenFish
« Reply #20 on: May 26, 2016 - 11:41:41 AM »
I was just about to ask you if it was a backfire or a pop/ping noise? Because this was my first thought, a plug boot/wire arching out. Has happened to me a few times and I keep plug boots in the car with me now.
« Reply #21 on: May 26, 2016 - 08:59:38 PM »
Glad you found a couple of problems  :2thumbs:
