Author Topic: Should I skim coat?  (Read 963 times)
Offline shadango
Should I skim coat?
« on: May 23, 2016 - 01:34:39 PM »
So we have the hood to bare metal on the underside and about halfway stripped on the top side...that means we are getting close to filler and paint time, so I am getting nervous ...kinda like that goofy chihuahua dog that sits and shakes constantly....LOL  :bigsmile:
The hood I have is in decent shape but does have a couple small spots where I know we will need to fill.
As a novice, should I skim coat the whole hood and use a "long block" to sand?
Or am I better off not doing that?
Also, I know the "durablock" product is what the pros use....but damn they get pricey when you start looking at the 16-24" ones for large panels like the hood........any cheap alternatives you guys have used?
I found that I have a pneumatic long board sander -- its an oldie and given to me some time back....2 or 3 " wide and maybe 12-14" long.....maybe that will work?
« Last Edit: May 23, 2016 - 01:51:58 PM by shadango »
Offline shawge
  • Zoiks!!
Re: Should I skim coat?
« Reply #1 on: May 23, 2016 - 02:02:47 PM »
 :2cents: I would fill and sand the known low spots, use a skim coat + guide coat over the hood to get everything near straight, then some high build to get it flat, finally seal/paint.  Or you can spray a coat of poly, do your guide coat + sanding, seal/paint.
I've used paint sticks or cut down yard sticks with paper wrapped around it, super cheap at the hardware stores. You can laminate two yardsticks together to get a stiffer "block" to prevent too much flex.
- Jerry
Offline shadango
« Reply #2 on: May 23, 2016 - 06:38:53 PM »
Thanks for the idea about yard sticks.....!
I guess I a must a little (lot) nervous about this.....never did a real skim coat before....or blocked.......have played with filler before, just not an entire HOOD covered in it.
Offline jimynick
« Reply #3 on: May 23, 2016 - 10:19:29 PM »
I wouldn't skim the whole hood. Unless you're well experienced in the art- and it is an art- of blocking, you'll regret it. Shawge gave you some good advice. As for the Durablocks, I just ordered a 5 piece set. I also ordered the 24" one which was $27 Cdn for it alone, not too hideous. The rolls of PSA sanding paper aren't cheap @ about $40 for a large roll, but if you want the thing straight and flat it's the price of admission. Cross file it when you do it as well. Good luck   :cheers:
Offline js29no
« Reply #4 on: May 24, 2016 - 12:34:16 PM »
 :iagree:  :thumbsup:
Offline rhamson
« Reply #5 on: May 25, 2016 - 08:38:39 AM »
I have never skimmed the whole area for filler as you have to flatten areas that didn't need it in the first place. A good feel by touch is also needed if you are a novice. I only fill the area necessary and glaze or spot putty around it if needed. A good way to see how straight the body work is to wet sand the car and watch the wet areas for any ripples or waves. I have gotten that glass look far ahead of putting any finish paint on it. Good luck. Remember cross sanding is your friend.
