Author Topic: Window louvers touching rear window glass  (Read 1261 times)
Offline dave73chally
« on: May 23, 2016 - 04:52:23 PM »
The underside rib on my rear window louvers are resting on my rear window in 1 spot. I've tried to fit them better but it's still running. With the pins in, they are tight but will this be an issue? Any suggestions? Thinking a piece of rubber on the rib that is rubbing?
73 Challenger
Re: Window louvers touching rear window glass
« Reply #1 on: May 25, 2016 - 09:17:10 PM »
SO I assume this is an aftermarket repop ?
 the edges around the top & sides should have a rubber seal on them , the pins should hold them tight but it should never be touching on the glass !
So you could trim the inside of the slat that is touching  , a die grinder would trim it quick
« Reply #2 on: May 25, 2016 - 09:21:22 PM »
Mine is close but not touching. It can with a rubber "gasket?" that rests on the glass, you could do the same thing with a slit rubber hose in a couple places.
« Reply #3 on: May 25, 2016 - 10:51:55 PM »
Yea they are repops from dales. I've trimmed the underside but they keep touching the glass at some point or another. Don't want to trim anymore, getting a little close to the spot welds! I'm going to have to use a slit rubber hose.
73 Challenger
« Reply #4 on: May 26, 2016 - 12:02:49 AM »
What about shimming up the hinges  1/8" Some aluminum sheet shaped like the hinge, then painted black? Just a thought?  :dunno:
« Reply #5 on: May 26, 2016 - 08:07:00 AM »
The pins at the bottom side are up more than I'd like already, afraid if I shim the hinges then I won't be able to engage the pin.
73 Challenger
Offline 1 Wild R/T
« Reply #6 on: May 26, 2016 - 10:01:15 AM »
My buddies T?A is an original louver car, he's owned it since the miid 70's, It;s always had a rubber strip on the center rib...
Offline YellowThumper
  • I left the snow for this?
« Reply #7 on: May 26, 2016 - 12:15:27 PM »
Is your rear glass Oem or is it a replacement piece?
If replacement it could have an incorrect curve to it.
Just a thought...
« Reply #8 on: May 26, 2016 - 01:04:03 PM »
Just a thought...
Don't know...was in it when I got it. Going to add some rubber and forget about it  :cheers:
73 Challenger
« Reply #9 on: May 26, 2016 - 01:20:55 PM »
 :2thumbs:
