Would it also be possible to gain results by changing up or down the hi speed air bleeds?
this is on the list too but it I'm tempted to swap jets before air bleeds.
I am going to need to check out this adjustable vacuum thing, my screw is pretty damn far out but that is how it came form the factory. I am quickly feeling like I got a carb that was returned because so many things seem excessively off.
1. my choke was 100% as far as it could go to the lean side
2. My secondary adjustment screw had already been turned around (turns from the top not the bottom)
3. Transition slots were not only completely exposed but by a good 1/8 of an inch above the end of the groove
4. the cam on the choke has a significant modification in it.
5. Accelerator pump was so loose it barely made contact.
I don't feel like ProForm would send carbs out like this? but summit claimed it was drop shipped right from them.
Anyways with lots of help and anger I am going to make it right.
