Author Topic: what color/sheen paint is correct for the dash  (Read 2490 times)
Offline culp71
« on: May 25, 2016 - 11:27:10 AM »
what sheen paint should be used for the dash components (metal parts) like glove box door etc.
black,
but what sheen, completely flat, semi flat, gloss ?
(want closest to original)
smooth, textured?
Re: what color/sheen paint is correct for the dash
« Reply #1 on: May 25, 2016 - 11:49:01 AM »
Originally, it was a "suede" paint that had a very slight texture to it.  That paint is still available but it's pretty expensive.  If you are on a budget, you can use SEM Trim Black.  On your last coat, lightly spray the paint from a farther distance and you can get a very slight texture in the finish. :2cents:
Offline culp71
« Reply #2 on: May 25, 2016 - 12:33:30 PM »
I did this "slight texture trick" on other parts but just was trying to
determine if the color sheen was to be flat or semi gloss,
sounds like a semi might be the way to go? would think that's close to "suede"
« Reply #3 on: May 25, 2016 - 12:36:34 PM »
What ever label you want to put on SEM Trim Black.  I consider it to be semi-gloss.  Definitely not flat.
Offline culp71
« Reply #4 on: May 25, 2016 - 12:54:17 PM »
perfect.
Offline anlauto
« Reply #5 on: May 25, 2016 - 01:01:57 PM »
You need more flat then gloss :2cents:
Offline js29no
« Reply #6 on: May 25, 2016 - 01:05:25 PM »
    :iagree: they also make A black etch primer, I use it for any bare metal if I brake through.
Offline 750-h2
« Reply #7 on: May 25, 2016 - 08:43:21 PM »
To get the proper texture I first paint the metal parts with a Rustoleum dark pewter textured paint. This will give you the proper texture. Once its dry do not sand it but top coat it with an enamel semi gloss black. By just painting with semi gloss paint you will not have that OEM suede looking finish.
« Reply #8 on: May 25, 2016 - 10:28:41 PM »
Trial and error
bought gloss black
flattener
and texture additive
Kept spraying on a thick paper till I liked it.
Offline 1 Wild R/T
« Reply #9 on: May 26, 2016 - 01:09:01 AM »
Powder Coat....
