Author Topic: Alternator Upgrade  (Read 2332 times)
Offline shatar4
  • 71 Challenger
Alternator Upgrade
« on: May 26, 2016 - 12:53:32 PM »
Just got my 505 up and running but noticed that the 80 amp. alternator cannot keep up with the Contour fans that I have installed. I need a bigger alternator to keep the battery charged but after looking at the Mopar brand, there's has to be a cheaper alternative. GM maybe?
« Last Edit: May 26, 2016 - 12:59:54 PM by shatar4 »
1971 Triple black 340 Challenger
Re: Alternator Upgrade
« Reply #1 on: May 26, 2016 - 08:25:21 PM »
Common problem cooling fans eat a lot of power , add electric fuel pump & water pump & EFI & 120 amps is the starting point !
 I had a custom Ford alt built by a refurbisher & customized the mounting , it made 120 amps with the external regulater still used
« Reply #2 on: May 26, 2016 - 08:53:11 PM »
« Reply #3 on: May 26, 2016 - 09:05:01 PM »
Not cheap but this is what I'm using. Works well!  :2thumbs:
http://www.qualitypowerauto.com/item_557/Chrysler-Mount-Mega-Amp-Alternator.htm
You powering up Barry?!?  :bigsmile:
Seriously, what are you running that draws sooo much power?  :clueless:
« Reply #4 on: May 26, 2016 - 09:36:27 PM »
Electric fuel pump, 2 electric fans, MSD, tranny controller,
Offline shatar4
  • 71 Challenger
« Reply #5 on: May 27, 2016 - 01:56:53 AM »
I looked at those. Very nice alternators but I don't think the accountant (wife) would go for that.
When I do change this, I'm thinking I'm going to have to change the wire to a bigger gauge like a 8-10 gauge going to the battery. I already did the bulk head bypass so thats not an issue.
Offline Bucks70RT
« Reply #6 on: May 27, 2016 - 07:22:22 PM »
I run a Denso 90 amp alternator on my small block. The Denso 120 amp is the same configuration. Rock auto $95. Had to modify the adjuster bracket and change the pulley.
Offline Bucks70RT
« Reply #7 on: May 27, 2016 - 07:24:41 PM »
Also one on my Demon 440.
Offline Cudakiller70
« Reply #8 on: May 28, 2016 - 12:03:13 AM »
Wow making your car a backup generator for your home !
The above is just my opinion
John Adams
« Reply #9 on: May 28, 2016 - 06:39:33 AM »
Naw.... portable welder!  :icon16:  One year while driving the 7 1/2 hour trip to Carlisle ( I only had 1 electric fan at the time, now I have 2) the 100amp alternator I was running couldn't keep up and left me stranded at a gas station about 1 1/2 from Carlisle. The battery was totally dead, I had to buy another one locally. I didn't want a repeat performance of that so I got the 250 amp 1 wire version. The old set up was fine for just running around locally as I'd put on the battery tender when not driving the car, but on a long trip is when the alternator showed it wouldn't keep up.
« Reply #10 on: May 28, 2016 - 07:28:26 AM »
What size wire do you use between the generating station and battery?  :bigsmile:
« Reply #11 on: May 28, 2016 - 01:20:35 PM »
Just some old lamp cord I had laying around , why?  :dunno:  :clueless:
 :lol:  I mounted  my battery in the trunk, and used welding cable for the main line running from the battery to the engine compartment.
