Author Topic: Any negatives to removing under hood insulation?  (Read 2622 times)
Offline Cudakiller70
« on: May 26, 2016 - 07:58:15 PM »
Installing an RPM air gap and checking air cleaner clearance, this manifold is taller and I'm looking at drop base air cleaners and need every inch to clear hood. The insulation is not tight to hood underside and I would like to remove it. Other than sound are their any negatives to removing the under hood insulation?
The above is just my opinion
John Adams
Offline YellowThumper
  • I left the snow for this?
Re: Any negatives to removing under hood insulation?
« Reply #1 on: May 26, 2016 - 08:19:17 PM »
I currently have that intake on my 360.
No issues here wit out the insulator.
Yes it is close but it works.
Seems to me most of the E Bodies I have seen are without them
« Reply #2 on: May 26, 2016 - 08:29:38 PM »
Hmmm less weight , less heat trapped , less dirt trapped above the AC , why was it installed again  :clueless:
« Reply #3 on: May 26, 2016 - 08:36:46 PM »
I have a 3/8 insulator that I was hoping to use? What carb and air cleaner are you using?
LOL OK CP Thanks!  :2thumbs:
John Adams
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #4 on: May 26, 2016 - 09:01:30 PM »
Not sure of the authenticity but I have heard it was intended to reduce the chance of a steam impairing your visibility.
With a hot hood, if it started to rain you could have steam coming off the hood.
I don't run a pad but I don't drive in the rain either...  :dunno:
I do have a brand new pad and clips but after I had it painted I just could not bring myself to cover that nice looking paint on the bottom of the hood.
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
« Reply #5 on: May 27, 2016 - 10:37:23 AM »
This is the best I came up with.
There is a 7/8th thick spacer. 1 inch I milled down to be flat again. The filter is just the cheapest generic one I could find. Temp until EFI and throttle body conversion.
Believe filter is 2.5 high. There is also a drop in the housing.  Not sure how much. Could look and measure if you are interested.
This pic is without spacer. It was only added so the carb linkage clears fuel rails. And... no I am not running both. Rails are blocked off. Carb is temporary to allow me to still drive it. Take it off, try efi. Fail, put carb on and drive. Repeat... lol
« Last Edit: May 27, 2016 - 10:48:42 AM by YellowThumper »
« Reply #6 on: May 27, 2016 - 11:34:14 AM »
Thanks for the info Mike. I'm going to remove the under hood insulation and see exactly how much room I have for an air cleaner.
Looks like youre keeping busy by that picture or pulling your hair out and both.  :2thumbs:
John Adams
« Reply #7 on: May 27, 2016 - 10:42:03 PM »
Removed the under hood insulation, heavens to murgatroyd there is lots of room, even with the stock dorky air cleaner!  :crazy:
John Adams
« Reply #8 on: May 27, 2016 - 11:02:24 PM »
Under hood insulation was part of the sound deadening package. When you ordered that package you got under hood insulation and full under body undercoating. Its sole purpose was to make the car feel more upscale and refined. You aren't going to hurt anything by removing it.
« Reply #9 on: May 27, 2016 - 11:52:54 PM »
Yessir there is lots.
Glad it will work for you.
Took a better pic of mine but now you are good to go without it...
Offline Cudaragtop
« Reply #10 on: May 28, 2016 - 10:15:14 AM »
I changed from the stock Round air cleaner to an Oval but I had to cut the throat down about 7/8". It's a Repoop...  :poopoke:
That's plumbers putty to check clearance. 7/8" at the center, everywhere else has over an inch.
- Randy D.
« Reply #11 on: May 28, 2016 - 01:58:08 PM »
That does look really good! Just love the mopar oval air cleaner, definitely one of the better designs. I did see your thread on your air cleaner and decals and I am thinking if getting one, but trying to slow the money throw at this car a little bit. Their are other things in life almost as important!    :bigsmile:
Nice detailing on the engine bay Looks really good and clean, nice job there Randy!
« Last Edit: May 28, 2016 - 02:03:53 PM by Cudakiller70 »
John Adams
« Reply #12 on: May 28, 2016 - 10:03:27 PM »
 I would use a Coolcarb spacer  1/8 " thick & more effetive
« Reply #13 on: May 29, 2016 - 12:19:18 PM »
murgatroyd
Always wondered how you spell that word...  :grinyes:
Still have no idea what it means...
« Reply #14 on: May 29, 2016 - 12:42:05 PM »
Ok LOL you prompted me to look it up
'Heavens to Murgatroyd' is American in origin and dates from the mid 20th century. The expression was popularized by the cartoon character Snagglepuss - a regular on the Yogi Bear Show in the 1960s, and is a variant of the earlier 'heavens to Betsy'. Despite etymologists' best efforts there isn't any record of the phrase that predates the cartoon series and it seems quite likely that it was coined by the show's writers.
Heaveans to MurgatroydAs with Betsy, we have no idea who Murgatroyd was. The various spellings of the name - as Murgatroid, Mergatroyd or Mergatroid tend to suggest that it wasn't a reference to an actual person but just a fanciful expression made up because it sounded wacky.
No fewer than ten of the characters in Gilbert and Sullivan's comic opera Ruddigore, 1887, are baronets surnamed "Murgatroyd", eight of whom (or is that which?) are ghosts.
Where then did the librettist Sir William Gilbert get the name? It seems that Murgatroyd has a long history as a family name in the English aristocracy. In his genealogy The Murgatroyds of Murgatroyd, Bill Murgatroyd states that, in 1371, a constable was appointed for the district of Warley in Yorkshire. He adopted the name of Johanus de Morgateroyde - literally John of Moor Gate Royde or 'the district leading to the moor'.
Whether the Murgatroyd name took a trip from Yorkshire to Jellystone Park we can't be certain. Unless there's a Betsy Murgatroyd hiding in the archives, that's as close as we are likely to get to a derivation.
John Adams
