Runnin 205 deg...too hot ???
Author Topic: Runnin 205 deg...too hot ???  (Read 3326 times)
Offline cudabob496
Re: Runnin 205 deg...too hot ???
« Reply #30 on: June 02, 2016 - 10:53:30 PM »
Also, having idle rpm around 1000 or higher, means the water pump (being centrifugal, and not postive displacement) will be more efficient,and
provide more cooling, when you are at idle at a stop light.  So will your alternator I suspect.
« Last Edit: June 03, 2016 - 01:17:37 AM by cudabob496 »
2011 Kawasaki Z1000
Offline brasil
« Reply #31 on: June 03, 2016 - 03:30:14 AM »
idle at 1100 rpm...  hmm   isn´t that a little high ?  When I let the engine idle so fast....  it will make a hart  hit into my rear end...when I go into  REVERSE..
also I need to modify the advance curve in the Distributor.......   now the curve begins @ 900-950 rpm....
Greetings Juergen
