Author Topic: A pillar hole spacing  (Read 894 times)
Offline glovemeister
« on: May 27, 2016 - 02:39:58 PM »
Am attempting to install a drivers side a pillar. I've discovered that it appears that holes at the hinge area are .5"-1" away from where they are supposed to be.  Can anyone measure these holes from the ground side/edge of the a pillar and let me know what the measurements look like?
If the a pillar goes under the firewall the .5-1" wrong is what I get. If I put the pillar on top of the firewall and under the cowl, they are dead on, but then I am pushed out .25-.5" from the cowl side, as the curved area on the a pillar is on the firewall edge instead of cowl area side panel.
1971 Challenger RT
Re: A pillar hole spacing
« Reply #1 on: May 27, 2016 - 03:28:39 PM »
If I remember correctly, the hole spacing changed at some point.  On my original 73 A-pillars, you can kind of see the spots where the holes used to be in the earlier years.  I wonder if you have the wrong year A-pillar trim?
« Reply #2 on: May 27, 2016 - 03:34:35 PM »
Here are a couple threads that mention the different screw hole placement.  Some say 70 and 71 are the same   Others are saying that 70 is a one year only piece.  What year are you working on?
http://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/7081119/site_id/1
http://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/7646203/site_id/1
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #3 on: May 27, 2016 - 04:37:19 PM »
actually 4 different versions on the E body A pillar trims. 70 2 hole , 71-72 1 hole , 73 1 hole ,74 1 hole . the physical trims are the same, just hole locations have moved.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
« Reply #4 on: May 28, 2016 - 12:12:49 AM »
Thanks for all the replies guys I really appreciate the information.
Just to confirm I am talking about the a pillar body itself and where it is spot welded over the top door hinge area.
1971 Challenger RT
Offline A.Gramz
  • In over my head!
« Reply #5 on: May 29, 2016 - 02:49:12 PM »
Pic of the area?
73 Challenger
Ontario Canada
