Author Topic: Shorty plugs for eddy heads  (Read 990 times)
Offline GreenFish
« on: May 28, 2016 - 10:19:39 AM »
Hey guys, My #2 spark plug boot keeps burning though. I've tried the fireproof sock but that doesnt work either. The problem is the spark plug tip practically touches the header so no matter what I put in there it's going to actually touch the header. Just looking at it , a shorter spark plug should solve the problem but not sure what would work with the edelbrock heads. I use the Champion RC12YC now.
Offline cudabob496
« Last Edit: May 28, 2016 - 03:47:42 PM by cudabob496 »
2011 Kawasaki Z1000
Re: Shorty plugs for eddy heads
« Reply #2 on: May 28, 2016 - 08:13:09 PM »
Accel generally has the shortest plugs available
Offline cudabob496
« Reply #3 on: May 29, 2016 - 12:41:31 AM »
you could also try header wrap, and/or make a thin metal shield
that bolts to a valve cover bolt, in addition to a shorter sparkplug.
I put some 1 inch diatmeter aluminum tubing around my boots, that
I got from an aluminum broom handle. The expensive sock type stuff
can catch fire.
2011 Kawasaki Z1000
Offline SirRalliart
« Reply #4 on: May 29, 2016 - 05:23:56 AM »
Agreed.  The wife uses those on her 440, but she's running stock heads with headers.
1971 Dodge Challenger R/T (Top Banana)
1972 Plymouth 340 Duster (TX9 Black)
1974 Plymouth 'Cuda360 (Deep Sherwood Metallic)
1978 Plymouth Volare Street Kit Car (#43, 2-tone Blue)
2014 Dodge Ram 1500 (Pitch Black)
2015 Dodge Charger SE (Granite)
2015 Dodge Callenger Hellcat (Phantom Black)
Offline YellowThumper
  • I left the snow for this?
« Reply #5 on: May 29, 2016 - 12:00:12 PM »
Would adding a dent to your header in that area help?
Offline GreenFish
« Reply #6 on: May 30, 2016 - 10:18:00 PM »
Thanks guys,
Yes I'm using a 90 degree now and it touches the header. I saw accel plugs and they also sell wires with boots rated to 2000 degrees. I may put one on that plug and see how that works out.
 last resort will be a dent
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: May 31, 2016 - 03:58:52 PM »
Got a pic, would be interesting to see?
Offline cudabob496
« Reply #8 on: May 31, 2016 - 05:07:22 PM »
Thanks guys,
the 2000 degree rating is for radiant heat, and not contact, I suspect.  If contact, will still burn and melt and catch fire, I suspect.
but, the 2000 degree boots might work if you use some header wrap also.  Also, file down the spot on the boot that is connecting, but not too much.
« Last Edit: May 31, 2016 - 05:09:01 PM by cudabob496 »
2011 Kawasaki Z1000
