Author Topic: best tool to use - oil pump drive gear  (Read 1224 times)
Offline Mopar Thunder
« on: May 31, 2016 - 07:34:34 PM »
what is the best tool you use to move the drive gear under the distributor when you need to set the distributor to TDC?
« Last Edit: May 31, 2016 - 08:05:06 PM by Mopar Thunder »
Offline HP_Cuda
  • Mopar or No Car!
Re: best tool to use - oil pump drive gear
« Reply #1 on: May 31, 2016 - 08:20:07 PM »
I think by removing the distributor and turning the crank to tdc on number 1 then installing the distrib is what you want to do.
Maybe I'm not understanding correctly but are you talking about the distrib gear?
« Reply #2 on: May 31, 2016 - 09:19:13 PM »
Just use a large std screwdriver & twist the drive gear up cw or ccw depending which engine you have
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: May 31, 2016 - 10:05:30 PM »
I wouldn't do that with a bronze gear
Offline anlauto
« Reply #4 on: May 31, 2016 - 10:08:49 PM »
Why not ? How else are you going to properly set the gear ? :clueless:
Offline GoodysGotaCuda
« Reply #5 on: May 31, 2016 - 10:16:42 PM »
What Chryco said is how it's done. The slot in the middle is pretty much just for doing that...
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #6 on: May 31, 2016 - 10:39:50 PM »
The gear is bronze , the shaft is hardened steel
« Reply #7 on: June 01, 2016 - 06:27:21 AM »
Thanks everyone.  That is what I thought but wanted to double check since a friend of mine was doubting what I was telling him.  :thumbsup:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: June 01, 2016 - 12:49:53 PM »
 :clueless: I always set the motor to TDC on number 1 and then install the distributor.
But yeah ref the pic. Either you are right or you are 180 degrees out.
If the gears are meshed with the cam it won't turn - you will need to pull it up and reset.
« Last Edit: June 01, 2016 - 01:06:57 PM by HP_Cuda »
