camshaft retainer bolt.... w/o oil hole ??
Author Topic: camshaft retainer bolt.... w/o oil hole ??  (Read 1604 times)
Offline brasil
Re: camshaft retainer bolt.... w/o oil hole ??
« Reply #15 on: June 06, 2016 - 07:27:53 AM »
@ 73_Cuda_4_me...   I only changed the Timing chain...and the tensioner...  the Timingcover is the OEM one... but the cloyes chain..is  a little bit wider than the OEM chain...  just 1 mm...or 2.
The Tensioner is from Cloyes also..  and now after I mad the litte "upgrade" on the pump lever arm....everthing is fine !
Greetings Jürgen
Offline 73_Cuda_4_Me
« Reply #16 on: June 06, 2016 - 07:35:04 AM »
 :2thumbs:
Good job on the modification, and enjoy the ride!
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline brasil
« Reply #17 on: June 06, 2016 - 11:40:21 AM »
Thank YOU !!
 :cheers:
Greetings Juergen
