Author Topic: Which Sealant for the 4 outside header bolts in the water jacket (With PIC)  (Read 1139 times)
Offline daveh
Hey guys,
Which Sealant (See below) would be best for the 4 outside header bolts in the water jacket of my 340?
I'm using APP Chromoly Header Stud kit (below) not bolts since the engine is out of the car and it's going back from underneath the car attached to the K-member.  Since they aren't aluminum do I still need to use anti-seize to prevent galling?  Thanks
http://www.summitracing.com/parts/arp-445-1301
« Last Edit: June 02, 2016 - 05:38:47 PM by daveh »
Offline GoodysGotaCuda
Left one seems sufficient.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Racer57
I recently used the one on the far right without any problems. I use it all the time on threads whether its for water, oil, propane, etc.
Left & right are the same Permantex thread sealant just different pkg
 Even the locktite one is the same jut different maker
Offline captcolour
I would use the Permatex on the left.  It is good up to 400F.  The Permatex on the right probably contains more PTFE and is good up to 300F.  They are close but not the same.
