Author Topic: problems with Comp Cams hydraulic roller lifters on 440  (Read 7961 times)
Offline PlumCraZRT
Re: problems with Comp Cams hydraulic roller lifters on 440
« Reply #15 on: June 11, 2016 - 06:48:55 PM »
...second, the valve train geometry will be off side-loading the valves in operation, possibly bending a valve stem enough to bind in the guide.
If this is a big block (like the subject suggests) with a rocker shaft, the rocker to valve geometry does not change with pushrod length.  You're thinking of a small block chevy, etc where the whole rocker moves to adjust preload.
mmmmm.... Mopar.... *drool*
Offline 734406pk
  • Andy
« Reply #16 on: June 12, 2016 - 12:35:56 PM »
I'm probably over-thinking this part but what are your thoughts on push rod length moving it's cup and ball pivot point further away from the centerline of the rocker shaft?  I'm thinking (wrong maybe) that will decrease the effective lift similar to a 1.5 ratio rocker vs a 1.6 (extreme example).  Agree 100% on the Chevy! I've seen it happen!  :scared:
« Reply #17 on: June 12, 2016 - 12:48:39 PM »
It won't change the ratio but might roll off the valve tip as it won't be centered like it should be during the rocker arms travel.    Bottom line.... no don't do it. :D
Offline 734406pk
  • Andy
« Reply #18 on: June 12, 2016 - 12:58:20 PM »
Offline HP_Cuda
  • Mopar or No Car!
« Reply #19 on: June 13, 2016 - 12:51:06 PM »
Or get custom length pushrods to match what you got!
Offline multiflu
« Reply #20 on: September 04, 2016 - 06:29:41 PM »
hay
went on a business trip for a long time had just returned!
and back to old problems  :working:  ))))))
I ordered a new spring!
but i am not sure that srings will solve the problem! i did not run my engine more then 2500rpm? and the whole trip was 10 minutes long
lifters stuck at the bottom and its not 1 or 2 ITS 7!!!
3!!! pushrods pop out(they jumped out on top, from the rocker arm)
I hope that this spring - it will explain a problem with pushrods, but all NEW hydraulic roller lifter! and its not 1 broken, its like every  second!
I do not believe that compcams is that ****'y
« Last Edit: September 04, 2016 - 06:33:37 PM by multiflu »
monster
off
performance
and
road
Offline HP_Cuda
  • Mopar or No Car!
« Reply #21 on: September 04, 2016 - 08:00:19 PM »
Just an update, my prob was my machinist did set the lash correctly hence a loud valve train.
The one thing that keeps resonating with comp lifter problems is under rated springs. So if you are going to run .600 lift you better get a spring rated higher than that to be on the safe side (I.e. .650)
Keeping my fingers crossed I never see these probs but she is running beautifully now.
« Reply #22 on: September 04, 2016 - 11:06:16 PM »
Really , I sure do from experience  :2cents:
