Author Topic: Has anyone welded their rear valance and smoothed the gap?  (Read 3875 times)
Offline GoodysGotaCuda
« on: June 02, 2016 - 09:47:30 PM »
Curious to hear experiences and see pictures of those that have welded and smoothed-in their rear valance on an ebody.
Any out there?  :working:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline sassygreen
Re: Has anyone welded their rear valance and smoothed the gap?
« Reply #1 on: June 02, 2016 - 09:55:53 PM »
yes ,gives the car a more modern look. Unless you point it out no one notices.
Offline teslasbrain
« Reply #2 on: June 02, 2016 - 10:01:26 PM »
 :useless:
Offline sassygreen
« Reply #3 on: June 02, 2016 - 10:33:56 PM »
ok,
« Last Edit: June 02, 2016 - 10:37:25 PM by sassygreen »
Offline teslasbrain
« Reply #4 on: June 02, 2016 - 10:39:59 PM »
Offline jimynick
« Reply #5 on: June 02, 2016 - 11:02:47 PM »
You did say rear valence, right? Not the upper body panel? I'm into the body work on mine and did/will not weld in the rear valance, because the minute I do, I'll have to change a spring or exhaust component and that won't make me happy. Having said that, I DID weld in the upper body/quarter panel seams as shown. Every old E body seems to have a rotten trunk floor and most of the time it seems to come through those seams.  :cheers:
Offline YellowThumper
  • I left the snow for this?
« Reply #6 on: June 02, 2016 - 11:48:09 PM »
I have a spare one for my 74 that I will be welding up the spring perch openings. I moved the rear bumper in already.
Plan on also trying to slightly push it in in the middle by the licence plate. And... most likely I will weld in a filler strip to the top of it to hide the area that steps inward. Idea is to have the panel smoothly tuck up under the bumper.
Hopefully be able to get to it soon.
Mike.
« Reply #7 on: June 03, 2016 - 12:01:14 AM »
 :iagree: On a Challenger if you need to remove that gas tank or springs you would need to remove the valance.
« Reply #8 on: June 03, 2016 - 12:37:32 AM »
On my barracuda, I have changed springs without removing the valance. Not ideal, but could be done.
I'm not following why the fuel tank requires removing the valance, is that challenger only?
As far as exhaust goes, I am expecting to use clamped on tips for adjustability/service.
1976 Dodge Warlock
Offline dave73chally
« Reply #10 on: June 03, 2016 - 08:36:26 AM »
I welded up the bumper guard slots but did not weld the panel to the quarter. Was afraid of issues with what the others are saying.
73 Challenger
Offline anlauto
« Reply #11 on: June 03, 2016 - 08:49:25 AM »
Try and get at the J bolts :pullinghair:
« Reply #12 on: June 03, 2016 - 09:16:08 AM »
  Right, I was thinking they were on the back. Easy enough fix however
1976 Dodge Warlock
Offline 71340RT
« Reply #13 on: June 10, 2016 - 11:47:38 PM »
My 74 Challenger has had the opening welded up for the bumper guards and still has the cutouts for the exhaust tips. Is cleaner and I would not weld the sides solid but I have seen it done. Here are a couple of pictures of mine.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
