Author Topic: Bent Sway Bar Bracket  (Read 1747 times)
Offline headejm
« on: June 03, 2016 - 02:45:00 PM »
1970 Challenger RT 383. Has anyone seen a sway bar bracket bent to the front like this one? Everything else looks okay and the front end hasn't been in a wreck since at least 1980 (year I bought it). Not sure that with a new sway bar bracket everything will go back in place? You can also see that the sway bar link is close to touching the strut. Is it easy to tell if the sway bar is bent? Any thing else to worry about?
« Last Edit: June 03, 2016 - 02:49:42 PM by headejm »
Re: Bent Sway Bar Bracket
« Reply #1 on: June 03, 2016 - 04:50:23 PM »
The K-member bracket is just pulling the end link forward.  The end link bolt could be bent as well.  My guess is that a new bracket and new end links will take care of it.  You could remove the bar and post a picture of it.  We should be able to tell if it's bent.  My guess is it's OK.
« Reply #2 on: June 03, 2016 - 08:24:31 PM »
My guess is someone towed or tied it down using the sway bar. Is it just the one side that is bent?
Offline EB3-GranCoupe
  • BP23 U0B
« Reply #3 on: June 03, 2016 - 08:27:21 PM »
Towed it.  I have a set of bent onesjust like those for anyone that wants  that original "junk yard dog" look.  ha!
Offline BIGSHCLUNK
« Reply #4 on: June 03, 2016 - 11:03:35 PM »
I had a bent one too! Just replace it , and all good.  :cooldancing:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline headejm
« Reply #5 on: June 04, 2016 - 12:42:07 AM »
Thanks for the comments! The other side is not distorted at all.
Offline rUNCHARGER
« Reply #6 on: June 04, 2016 - 12:44:44 AM »
Common damage. I think you could straighten it by simply prying it with a long screwdriver using the bolt as an anchor point. The brackets are barely thicker than sheetmetal.
Sheldon
Offline YellowThumper
  • I left the snow for this?
« Reply #7 on: June 05, 2016 - 04:13:38 PM »
As all have noted probably caused from being pulled when  car was strapped down.
I had a flat one from being use as a lift point by a jack (@ss) when having tires installed.
Disconnect, disassemble and straighten or relpace.
Also... to save future remarks be sure to install all your mounting bolts in their "proper" orientation.  :stirpot:
« Last Edit: June 05, 2016 - 04:15:25 PM by YellowThumper »
