On flat surface, measure the fender lip on each of the front fenders from floor through the centerline of the wheel to the lip, and also check TB adjuster screws to see if they are the same length sticking out of the adjuster nut... I'm thinking the passenger side front is higher, and throws the driver's back corner down a bit on the springs...
