Author Topic: Custom shaker trim ring  (Read 3691 times)
Offline leanburn
« on: June 03, 2016 - 11:34:51 PM »
 I really want to run a 1" spacer under my carb, I've already modified the baseplate to the point that my distributor cap is almost rubbing so I can't go lower with my baseplate.  The only thing I can think of is to somehow cut about 3/4" off the trim ring to allow the bubble to sit higher. Of course I'm not willing to do that because I have 0 talent in that area, just thought I'd post to get some ideas or if maybe someone has done this before.
Offline rUNCHARGER
Re: Custom shaker trim ring
« Reply #1 on: June 04, 2016 - 12:49:31 AM »
I have the same problem with a friends 71 Cuda with a shaker and an Indy Hemi setup. I am thinking of dropping the K-member a half inch but that will put the valve covers into the shock towers. It would be easy with a wedge engine though. If you are running a stock fan shroud it wouldn't work either.
Sheldon
« Reply #2 on: June 08, 2016 - 09:12:14 AM »
so why the 1" spacer ?
 for heat you can run a Coolcarb spacer that is 1/8" thick , if it is for performance that is a different issue adding 1" is creating your own nightmare it seems .
Offline ragtopdodge
« Reply #3 on: June 08, 2016 - 09:16:57 AM »
 :iagree:
A lot of work for little gain IMHO.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline leanburn
« Reply #4 on: June 08, 2016 - 09:18:34 AM »
 It was an 8 horse gain on the dyno. I've been told it will help the efi with the vacuum signal as well
Offline ragtopdodge
« Reply #5 on: June 08, 2016 - 09:20:47 AM »
8hp not worth it IMHO.
Either go for looks or for all out performance if you need that.
Talk of dropping k-member, hacking trim rings...sounds all scary.
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline js29no
« Reply #6 on: June 08, 2016 - 11:22:05 AM »
It seams to me if you drop your K-frame your pinion angle will change on the transmission, the tail shaft will point up more. :2cents:
Offline YellowThumper
  • I left the snow for this?
« Reply #7 on: June 08, 2016 - 02:08:27 PM »
My off the cuff calculating of angle change would be less than 1/3 degree change for a half inch drop.
This is a loose guess because I don't have an exact measurement distance between motor mounts and trans mount (the pivot point).
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #8 on: June 08, 2016 - 03:04:36 PM »
YUP
« Reply #9 on: June 08, 2016 - 06:35:12 PM »
It will also negatively effect the front end geometry....
Offline js29no
« Reply #10 on: June 09, 2016 - 09:06:11 AM »
Stress on torsion bars, cant run A radiator shroud, alignment issues!!! I would not do it!!! :nono:
Offline Cudacat
« Reply #11 on: July 18, 2016 - 11:10:32 PM »
There are lots of easier ways to gain 8 HP than what you are proposing.
Offline leanburn
« Reply #12 on: July 20, 2016 - 09:01:39 AM »
Well I'm always interested in adding a few ponies, let's hear what tricks you got up your sleeve that I haven't already done.
Offline Racer57
« Reply #13 on: July 20, 2016 - 03:47:41 PM »
I did this using Reflectix and also placed a piece of Refectix that's double thickness on top of the valley pan and it made a lot of difference with vapor locking.
« Reply #14 on: July 24, 2016 - 08:37:16 PM »
just breathing through the shaker will cost you HP , 8 hp is not worth the hassle , if you want the power then a Trans Am hood would be better
