Author Topic: Hotchkis LCA pivot shaft question  (Read 999 times)
Offline JoeGrapes
« on: June 04, 2016 - 12:43:53 PM »
I'm changing out the old suspension components with Hotchis stuff. I also welded  stiffing plates to the LCA's and changed out the bushings and pivot shafts with the Hotchkis #3006 Pivot Shaft Kit. I have the LCA's all assembled and I'm putting them back on the car. Imagine my surprise when the new Hotchkis pivot shaft is to small in diameter for the mounting hole. WTF, the hole is about .93 ID and the pivot shaft is about .8 OD. The package they sent me is listed with the right numbers. I called them but they are not open on weekends. Has anyone had this problem?
Offline GoodysGotaCuda
Re: Hotchkis LCA pivot shaft question
« Reply #1 on: June 04, 2016 - 05:25:17 PM »
following, I was planning on using their pivots on mine.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 1 Wild R/T
« Reply #2 on: June 04, 2016 - 09:18:21 PM »
They supplied the bushings & the shafts?  The .93 is the ID of the bushing? & the .8 is the O/D of the shaft where the bushing rides?  I have no parts here so this is just a guess, Std rubber bushings have an inner sleeve made of steel, it probably has an O/D of .93 & an ID of .8.... So next you'll discover the bushing OD is smaller the the hole in the control arm... Again the steel sleeve from a stock bushing would take up the space...  Surprised Hotchkis would get that wrong but it sure seems like they did...
Offline 73440
« Reply #3 on: June 04, 2016 - 09:38:38 PM »
http://files.hotchkis.net/instructions/21366.pdf
Looks like you have to reuse your old inner and outer steel bushings.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline JoeGrapes
« Reply #4 on: June 05, 2016 - 06:18:23 AM »
It looks like they gave me A-Body pivot shafts. Not sure if the bushings are the same until I talk to them.
