Author Topic: timing chain assembly  (Read 584 times)
Offline Challenger in NC
« on: June 05, 2016 - 07:00:59 PM »
I have my timing chain assembled and would like to know if any assembly lube is required. No mention is made by Comp Cam instructions. The timing chain will get oiled shortly after engine start up but what is standard procedure? I might lightly coat the chain, gears with some oil but do not want to dowse it to the point it drips all over the gasket surface of the block. One source shows the chain being packed with axle grease.
Chris
Offline 73_Cuda_4_Me
Re: timing chain assembly
« Reply #1 on: June 05, 2016 - 07:30:37 PM »
Priming oil pump should put oil on the sprockets before you start it, and they have some assembly lube on it when purchased...
 :2cents:
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
« Reply #2 on: June 05, 2016 - 07:53:13 PM »
 :2cents:
Ah yes, I do have a drill attachment to prime the engine, good point.
Thanks
Offline rUNCHARGER
« Reply #3 on: June 05, 2016 - 08:27:09 PM »
I soak them them in oil before installing.
Sheldon
« Reply #4 on: June 05, 2016 - 08:39:45 PM »
Sheldon
I might put a very light coating of assembly lube on the chain for added insurance.
