Author Topic: 69 Fastback G3 Hemi Father Son Project  (Read 47551 times)
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
Re: 69 Fastback G3 Hemi Father Son Project
« Reply #165 on: December 15, 2017 - 03:22:38 AM »
I tried to copy and paste the link multiple times but it's not working the way it used to.  :banghead:  :dunno: :clueless:
It shows in the preview but not after I post it.
https://youtu.be/N_x-3oK2Jx0
www.youtu.be/N_x-3oK2Jx0
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline djw383
« Reply #166 on: December 15, 2017 - 09:00:58 AM »
No need to go any further, I would just roll that out in the driveway and let it run all day Sundays
Offline Cudaragtop
« Reply #167 on: December 15, 2017 - 09:35:59 PM »
I do love racking up the video and casting it to my big screen and cranking the volume on the surround sound.  :bigsmile:
- Randy D.
Offline Cudaragtop
« Reply #168 on: December 15, 2017 - 09:45:04 PM »
Put my new HF Engine Hoist together. Got the engine on the hoist so I can remove the wood shipping braces. Think I will have to change the Pan and Pickup first. Also plan to mod the Passenger Biscuit Mount. If I move the mount to the rear on the QA1 K-Member and cut down the mount itself to shorten it towards the rear, I'll have more room for the dipstick and Oil Filter Adapter and not have to cut down the rubber biscuit.
It got dark and I'm outdoors so more pictures tomorrow.
Will be putting the 8-3/4 together tomorrow. Can be seen in the background.
- Randy D.
Offline Cudaragtop
« Reply #169 on: December 15, 2017 - 09:51:12 PM »
Move the passenger side mount as marked in red...
- Randy D.
Offline 70chall440
« Reply #170 on: December 16, 2017 - 01:02:51 PM »
Current Mopar
Past Mopars
Offline Cudaragtop
« Reply #171 on: December 16, 2017 - 08:28:19 PM »
Might need one of these
https://www.ebay.com/i/112633173852?chn=ps
I give. What's it for and why would I need it?  :dunno: :clueless:
- Randy D.
Offline Cudaragtop
« Reply #172 on: December 16, 2017 - 09:39:20 PM »
A little more progress today.
Got the 8-3/4 installed in our narrowed housing.
New Yukon 489 case, 3.55 Clutch Type Sure Grip - Randy's Ring and Pinion
New custom Dr. Diff Axles installed, new Perches moved in, new Housing ends - All Dr. Diff.
Jeep Grand Cherokee Disc Brakes - E-Bay
« Last Edit: December 16, 2017 - 09:41:11 PM by Cudaragtop »
- Randy D.
Offline Cudaragtop
« Reply #173 on: December 17, 2017 - 04:25:01 PM »
Rear end with the Calipers and Rotors.
I went with the Jeep Grand Cherokee Disc Brakes for the incorporated Drum E-Brakes and the common replacement parts.
Same as Ferd Exploder...
Should work well on our +/- 3000 lb. Barracuda if they worked on 4130 lb. Grand Cherokees.
- Randy D.
Offline cudamadd
    • cudamad157071@gmail.com
« Reply #174 on: December 17, 2017 - 04:32:00 PM »
Nice job coming together very nicely  :2thumbs:
Go 4 a spin Ya Why Not.
Offline 70chall440
« Reply #175 on: December 17, 2017 - 07:48:48 PM »
Its a engine lift for a new gen hemi; basically like the old 4BBL plate where you hook the hoist to. I think I would make one before I bought one though.
Current Mopar
Past Mopars
Offline Cudaragtop
« Reply #176 on: December 17, 2017 - 08:38:24 PM »
How's this? The straps are rated for 6400 lbs. each. just need to lift it high enough to set it on my K-Member on the K-Member stand.
Going to lower the car onto it.
« Last Edit: December 17, 2017 - 08:41:07 PM by Cudaragtop »
- Randy D.
Offline 70chall440
« Reply #177 on: December 18, 2017 - 12:04:55 AM »
Yeah, that works. I was just passing it on in case it was something you thought interesting.
Current Mopar
Past Mopars
Offline Cudaragtop
« Reply #178 on: December 18, 2017 - 12:42:06 AM »
Thanks Mike.
Got my curiosity so I searched it. Couldn't find any pictures of it lifting or attached to an engine. Can't picture it.
Oh well, will spend that $ on something else.  :money:  :bigsmile:
- Randy D.
Offline 70chall440
« Reply #179 on: December 20, 2017 - 12:26:08 AM »
Several pictures here
https://www.reillymotorsports.com/3rd-gen-hemi-lift-bracket.html
You probably dont need it since you are installing the engine on the K member and then lowering the car onto it all. However if you were dropping the engine in from the top this would be very handy.
Current Mopar
Past Mopars
