Author Topic: proper finish for cuda transportation "tie down" bracket on rear of "frame"  (Read 1731 times)
Offline culp71
what was the original finish on the frame transportation "tie down" brackets and bolts on a 71 cuda?
body color, black , unfinished?
http://www.classicindustries.com/product/mopar/e-body-barracuda-1970-74/parts/me5054.html
thanks
« Last Edit: June 08, 2016 - 12:08:18 PM by culp71 »
Bare metal.
Offline culp71
brackets and bolts?
Offline anlauto
Never painted, bare steel, black bolts. I use Symore's Stainless Steel paint for those
Offline culp71
black bolts gloss or semi?
The bolts would have been phosphated from the factory.  That finish can vary from lighter gray to black.  Multiple places sell kits to darken hardware.  I use the black oxide kit from Caswell Plating.  You have to protect the finish from rust after you've darkened the color however.  There are a lot of uses for the darkening solution in a restoration.
« Last Edit: June 08, 2016 - 01:08:41 PM by burdar »
Here are a couple pictures of the Caswell blackening solution.
Offline culp71
detailed, I like it, thanks
Offline SBDave
What size thread is the hardware?
Thanks!
EDIT: it's a 7/16-14
« Last Edit: June 23, 2017 - 03:15:07 PM by SBDave »
