Author Topic: Cuda Dies?  (Read 4065 times)
Offline 73440
Re: Cuda Dies?
« Reply #15 on: June 11, 2016 - 12:16:10 PM »
734406pk, I like that idea to see all at one time.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 734406pk
  • Andy
Re: Cuda Dies?
« Reply #16 on: June 11, 2016 - 01:00:13 PM »
 :thumbsup: It's bailed me out many times, especially when working alone. I hope it helps!
Offline badcbr
Re: Cuda Dies?
« Reply #17 on: June 12, 2016 - 09:55:29 AM »
Sorry, let me clarify my last post, according to the posted wiring diagram the two blade posts are reversed so the power I referred to on the wire was the yellow ignition wire.  The larger gauge slanted wire goes to ground for neutral safety switch.  So, I know my fault lies between the bulk head and the ignition switch (I believe), I'm going to ohm the neutral safety switch today just to make sure I'm good there, I'm also going to let it run for a little while by starting it with the remote switch and see if it just dies again.
I will jiggle wires under the dash to see if I can get a hiccup, thanks for the inputs.
Offline 734406pk
  • Andy
Re: Cuda Dies?
« Reply #18 on: June 12, 2016 - 12:41:20 PM »
The bulkhead connectors are prone to corrosion. You will want to pinpoint the problem area with testing, this way you will know that the problem is fixed once and for all. It's no fun getting stuck somewhere. :stomp:
Offline 73440
Re: Cuda Dies?
« Reply #19 on: June 12, 2016 - 01:31:43 PM »
 I have had coils to get hot and the engine stalls
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline YellowThumper
  • I left the snow for this?
Re: Cuda Dies?
« Reply #20 on: June 14, 2016 - 08:10:51 PM »
The bulb option works well if you have a short that ends up killing battery when parked.
Disconnect battery lead and connect bulb between battery and disconnected lead. If bulb lights there is a short. Remove one fuse at a time until bulb goes out. Then reinstall fuse and further narrow down by disconnecting individual wires.
