Timing drives me crazy.....
Author Topic: Timing drives me crazy.....  (Read 5099 times)
Offline brasil
Re: Timing drives me crazy.....
« Reply #30 on: July 06, 2016 - 03:11:02 PM »
I limited  the advance,,,down to 10 deg...   but 10 deg is still too much...  and less ? Does it make sence to look for
2-4 deg.?? Don´t know...but I think it is a waste of time...
I think the CR is too high....Unfortunatly...I don´t konw...what they did with engine..when they rebuild the engine...in North Carolina..  ( perhaps they wanted to make a real Richard Petty Racer out of him ?? )
Flat Top pistons...  milled X Heads... HP Manifolds  71 Intake...  more than 180 PSI comression on each Cylinder...
unknown cam...  that need a huge number of timing @ idle...  and a carb that needs to be "upjetted" from 095 /1940
to 098 /1966 ....
if there were some signs of dripping oil...or something    I had a reason to pull the heads and the cam  just for knowing....  what `s going on....
Greetings Juergen
Offline Strawdawg
    • Vortex Buicks
« Reply #31 on: July 06, 2016 - 03:31:56 PM »
well, 5 degs is better than 0 degs, :D  but who knows if it will work-have to try it and see....or go up a notch on the cruise fuel.
sometimes, more can be better :)  I have found that many cars of this generation cruise best around 13.5-1 because fuel distribution is not as even as with port injection.  All it takes is one lean cylinder to get a little rattle.
I don't recall what you said about AF so you may be there already
Offline brasil
« Reply #32 on: July 06, 2016 - 05:23:13 PM »
Thank you strawdawg...
i will go up  with the Fuel ratio tomorrow...  and then hook up the VC again...   who knows..? the Idea is right..
I will keep you informed ..about the progress
Greetings Juergen
Offline 734406pk
  • Andy
« Reply #33 on: July 07, 2016 - 09:30:22 PM »
to 098 /1966 ....
Greetings Juergen
You may need to eliminate vacuum advance altogether if you have pinging at cruise. Most high compression engines use centrifugal only, 36 or so degrees all in... Can you get fuel with a higher octane rating or use an additive to increase the same?
Offline cudabob496
« Reply #34 on: July 08, 2016 - 12:44:03 AM »
I ditched my vac advance. Gave better throttle response.
2011 Kawasaki Z1000
Offline brasil
« Reply #35 on: July 09, 2016 - 05:27:04 PM »
 :working:
Result.....   No more pinging  :ylsuper:
What did I do ??...   I just slowed down the Timing Curve...  and changed the advance... @ Idle I have now 10 deg BTDC..24 deg advance ...  and....  14 deg from the VC....
AFR while cruising....14.5   WOT 11.8     Idle  around 13....
Thank you all for your advises and help !!
Greetinge Juergen
Offline Strawdawg
    • Vortex Buicks
« Reply #36 on: July 09, 2016 - 10:12:07 PM »
Good news  :jumping:
