Author Topic: Bigger the better?  (Read 762 times)
Offline cudabob496
Bigger the better?
« on: June 11, 2016 - 09:06:45 PM »
New Car Craft mag, article on carbs.  Comet drag car, 351 Windsor stroked to 425 cu in.
runs low 7s in eight mile, with automatic and 3.91 rear gears.
Tested 3 carbs, 650, 750, and 850.
850 make most power, 423hp, while 650 made 409hp.
At track, fastest times and top speeds in eight mile were
made with the 650 DP.
650 - 7.01sec, 95 mph
750 - 7.04 sec, 94mph
850 - 7.25sec, 89 mph
2011 Kawasaki Z1000
Offline stinger
Re: Bigger the better?
« Reply #1 on: June 11, 2016 - 11:44:34 PM »
according to my butt dyno my car is a lot faster with the 950 vrs. the 750.
Offline brasil
« Reply #2 on: June 12, 2016 - 12:50:04 PM »
I think the smaller carb will create more Torque....at the bottom end
Greetings Juergen
Offline cudabob496
« Reply #3 on: June 12, 2016 - 04:52:42 PM »
also, most say a smaller carb will give better throttle response.
If you are at 3000 rpm, and stab the throttle, a smaller carb
is going to move you quicker/faster. That's why I stay with an 850 DP with
annular boosters, rather than a 950. If I drag raced in the 1/4 mile, and kept
rpms up around 6000, then a 950 would probably be better. Annular
boosters also give better throttle response.
« Last Edit: June 12, 2016 - 04:54:45 PM by cudabob496 »
2011 Kawasaki Z1000
