Author Topic: Battery leaking??  (Read 2273 times)
Offline CUDA JAS
  • vroooooom!
Battery leaking??
« on: June 12, 2016 - 04:12:47 PM »
First drive of the year and i have these grey spots spattered all over my inner fender and a huge sploge of it under the battery.
The battery had fluid all over it...but I also had a power steering leak.
Did my battery leak fluid everywhere??
74 'cuda 360/727
Just call me a gearhead!
Offline Skunkworks Challenger
  • Mopars forever!
Re: Battery leaking??
« Reply #1 on: June 12, 2016 - 04:19:05 PM »
That's typical leaking battery damage.  Lucky you caught it when you did.  It's not uncommon for an older battery to leak and they can do enormous damage.
The Brewmaster
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: June 12, 2016 - 04:45:16 PM »
Well crap!!  Battery is only 3 years old. What would cause it to leak like that???
74 'cuda 360/727
Offline CUDA JAS
  • vroooooom!
« Reply #3 on: June 13, 2016 - 07:56:57 PM »
Well got them to replace the battery even though it tested fine.  They said it was clearly leaking.
They seem to think it got to hot and leaked.
Any thoughts on what would cause it to over heat?  Could a bad voltage reg be the cause??
74 'cuda 360/727
Offline tman
« Reply #4 on: June 13, 2016 - 08:48:38 PM »
Unless there is a crack in the case, overcharging can cause acid battery to leak.  Or if you keep a charger on the battery during storage, that can overcharge the battery, depending on the type of charger.  Best to use a battery maintainer for storage use.  If caps are removable, check the level.
Offline jimynick
« Reply #5 on: June 13, 2016 - 11:21:09 PM »
Jas, stick a voltage meter across the terminals when it's running and check the voltage. At fast idle, it should be approx. 14.2V. If the regulator is pooched, it may overcharge and cook the battery. How's the steering issue coming along? Ian
« Reply #6 on: June 13, 2016 - 11:35:32 PM »
Jas,
Buy the Northstar AGM or also called X2.
No more well cells in my car ever again.
« Reply #7 on: June 14, 2016 - 08:16:10 AM »
Jas,
I'm looking at doing that. They are on sale here locally...... :-\
Offline solarguy
« Reply #8 on: June 14, 2016 - 09:13:48 AM »
Don't forget to neutralize the acid with a good washing of the inner fender with baking soda and water.
Offline YellowThumper
  • I left the snow for this?
« Reply #9 on: June 14, 2016 - 08:14:00 PM »
X2 on this or it will keep eating.
« Reply #10 on: June 14, 2016 - 09:36:18 PM »
I bought one( Northstar, on Mike's advise) and installed it today , not cheap but anything good never is?
« Reply #11 on: June 14, 2016 - 11:48:30 PM »
Good move!   :2thumbs:
Heavy aren't they?
That's what happens when you have a battery with 100% pure lead.
« Reply #12 on: June 15, 2016 - 07:52:25 AM »
Heavy aren't they?
Yes they are a little heavier , glad it's mounted in the trunk!  :grinyes:
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #13 on: June 16, 2016 - 11:49:19 PM »
over charged
Offline CUDA JAS
  • vroooooom!
« Reply #14 on: June 18, 2016 - 08:36:16 AM »
over charged
Hmm. I did fire it up and check...multi meter says 14 ish volts across the battery.
I will keep an eye on volt gauge next time I have the car out.
Jason
74 'cuda 360/727
