Author Topic: Schematic amp meter bypass with battery disconnect  (Read 762 times)
Offline Cudakiller70
« on: June 12, 2016 - 09:06:17 PM »
 Does anyone know or have of a schematic they could share that incorporates both mad electric amp meter bypass and a battery/Alternator disconnect?
The above is just my opinion
John Adams
Offline 67vertman
  • Member since 9-23-2005
Re: Schematic amp meter bypass with battery disconnect
« Reply #1 on: June 12, 2016 - 11:25:55 PM »
Here is a website that has the amp meter bypass?
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
« Reply #2 on: June 13, 2016 - 12:36:59 AM »
Thanks vertman. I do have that, but again Thanks. I installed a battery/alternator cutoff switch after doing the amp meter bypass and regardless of switch positions (it's a good switch I did check it) was still getting power to the harness. After looking at an engine bay schematic realized the small wire from the positive battery terminal clamp that went to the starter relay was hooked up. So I cut it off at the battery terminal clamp and ran it to the battery/alternator switch.
I was having a problem figuring it out. Think I got it. We shall see. :2thumbs:
John Adams
