Author Topic: 4 speed and tti x pipe  (Read 2355 times)
Offline dave73chally
« on: June 13, 2016 - 04:51:12 PM »
I'm running a 4 speed in my 73 and was planning on buying a tti x pipe. Talked to Jamie at Passon, the reverse rod will have issues, tti said the same. What are you guys doing? Not running an x pipe?
73 Challenger
Offline 67vertman
  • Member since 9-23-2005
Re: 4 speed and tti x pipe
« Reply #1 on: June 13, 2016 - 05:09:32 PM »
I am running the H pipe.  I still had to get a later reverser shifter rod, as the rod for the 70 hit the H pipe.  No issues now that everything is as TTI said it should be.  They know there stuff.
Offline 4Cruizn
  • HEMI FISH
« Reply #2 on: June 13, 2016 - 09:26:53 PM »
Yeah my 73 4 speed has the H pipe as well . .  :dunno: :thumbsup:
« Reply #3 on: June 13, 2016 - 10:42:38 PM »
Jamie said that even if I got the 70-72 reverse rod I'd still have to bend it to clear the trans bracket?
73 Challenger
« Reply #4 on: June 14, 2016 - 09:05:41 AM »
I used a 3" x pipe TTi system on my 71 Charger 4 spd with no issues
« Reply #5 on: June 14, 2016 - 09:41:27 AM »
Jamie mentioned something about the way the trans brace mounts will cause interference with the reverse rod. Even if I went with a 70-72 like TTI says, Jamie mentioned I'd still have to bend it to work. Don't want to do that.
73 Challenger
Offline 67vertman
« Reply #6 on: June 15, 2016 - 11:02:57 PM »
You can get the later model rod 73/74 and you wont have to bend the rod.
Offline YellowThumper
  • I left the snow for this?
« Reply #7 on: June 16, 2016 - 01:32:57 PM »
Vertman,
Just curious...
Is the 73/74 rod the one that loops down and around?
That is what I have in mine. Not original to car though.
« Reply #8 on: June 16, 2016 - 01:53:25 PM »
Vertman,
Just curious...
73/74 if more a "J" while 70-72 is more of an "L"
From talking to tti, they said since I have a 73, I will NEED a 70-72 reverse rod to clear the X pipe. Also I've read a couple posts that claims that's the case and it'll work. My confusion came into play when I went to order one from Jamie at Passon and he didn't seem to think it worked, unless I misunderstood him?
Brewers specifically lists the 70-72 rod as compatible with a tti x pipe in the item description.
73 Challenger
« Reply #9 on: June 16, 2016 - 06:08:45 PM »
Thanks,
I have what you described as a J shape.
Trying to decide if I will try the TTI when I put in the 3".
Offline 67vertman
« Reply #10 on: June 17, 2016 - 11:03:46 PM »
Vertman,
Just curious...
Mike, I thought I went with the 73/74 style....however I double checked and I had to get the 70/72 one and yes it is like an "L" not a "J".  I have the TTI 2 1/2 inch exhaust.
« Reply #11 on: June 18, 2016 - 12:03:53 PM »
Thank you very much
