Author Topic: sail panels  (Read 2227 times)
Offline mopar jack
sail panels
« on: June 14, 2016 - 01:04:22 AM »
Got some new sail panels for my 71 cuda and like most after market parts they just don't bolt on without some persuasion. So tried one side and spring clip wouldn't line up and the cardboard material that holds the clip came off. Piece of s**t. Got the panels through Roseville and they are made by r.e.m. Are there better panels out there. These panels are flat and need to be rounded to match the contour of the roof.
Re: sail panels
« Reply #1 on: June 14, 2016 - 01:18:22 AM »
Same problem I went thru.
I found a place online from Washington state. They came pre curved with the material already on.
I just can't remember their name right now.
Hopefully this clue might jog somebody's memory on this place.
Offline mopar jack
Re: sail panels
« Reply #2 on: June 14, 2016 - 09:12:42 AM »
Thanks Mike, I'll keep searching on line.
Offline solarguy
Re: sail panels
« Reply #3 on: June 14, 2016 - 09:16:50 AM »
I glued the metal clip plate from the old one to the new ones I got years ago from year one.  Those had no provision what so ever for the clip.
Offline anlauto
Re: sail panels
« Reply #4 on: June 14, 2016 - 11:06:27 AM »
My headliner guy doesn't bother with those clips at all. :2cents:
Offline HP_Cuda
  • Mopar or No Car!
Re: sail panels
« Reply #5 on: June 14, 2016 - 11:47:31 AM »
Alan
Does he glue them on?
Offline fc7vw9
Re: sail panels
« Reply #6 on: June 14, 2016 - 12:34:42 PM »
I ordered the premium kit from Legendary, my headliner guy, had no problems with the headliner it was great. Also ordered the pre made sail panels....not worth the card board they are made of. My guy made new ones came out good. But not close to my survivor. At Spring fling in CALIF I found a set, just waiting for the matching material from Legendary. Maybe the guy doing the Gran Coupe/ SE headliners could make some accuarate reproductions???
Ron
Offline anlauto
Re: sail panels
« Reply #7 on: June 14, 2016 - 12:56:29 PM »
Alan
No glue, just fits them properly and relies on the coat hook and trim to secure them.
First picture is the original head liner....
Second is the new legendary stuff properly installed by my upholstery guy.
(same car)
Offline HP_Cuda
  • Mopar or No Car!
Re: sail panels
« Reply #8 on: June 14, 2016 - 12:58:56 PM »
So the coathook and the rear window trim pull it in along with the lower tab.
Hmm took me forever to get this to look right and I'm not doing it again!!!
My solution was to find thicker stock, epoxy it to the rear and then put the clip in. Worked a charm.
Offline mopar jack
Re: sail panels
« Reply #9 on: June 14, 2016 - 07:42:37 PM »
Well Alans suggestion worked. No clips and it looks much better than my originals. The trim and coat hanger hold it in place and  you use the interior panel to hold a curve in it.
Offline RusTy/SE
  • Just havin' fun
Re: sail panels
« Reply #10 on: June 18, 2016 - 12:24:05 PM »
(same car)
Alan, I've long considered that would be the best method where reinstalling those sail panels is a concern.  :thumbsup:
 :cheers:
« Last Edit: June 18, 2016 - 12:26:29 PM by RusTy/SE »
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline v21jeff
Re: sail panels
« Reply #11 on: June 29, 2016 - 09:06:55 AM »
I recovered mine with a heavy contact paper (vinyl really). Worked great.
