only different between 70 and 71-4 was the rivets and I believe the number of teeth on the hinge used.
with in the hinge there should have been an adjustment instruction sheet. IF not Contact Stephens performance as they are the source for those. Just supplied through AMD or Stephens.
sounds to me that the 2 front bolts on the hinge need to be pushed down. which is the opposite to adjust.
