Author Topic: Rallye gauges dont work fine  (Read 3539 times)
Offline Rafilla
« on: June 15, 2016 - 01:48:35 PM »
Hello to all
I have a problem in the rallye gauges. The fuel level and the oil pressure are out of scale
And the tachometer sometimes work and sometimes dont....
The out of scale is after a dash change and its possible a wire change.... But I dont know
Thanks and best regards
1970 Dodge Challenger
Green Go
440
4spd
Offline Rafilla
Re: Rallye gauges dont work fine
« Reply #1 on: June 15, 2016 - 01:50:18 PM »
The alternator gauge work fine. And the oil temp dont work because no sender in the engine
Green Go
440
4spd
Offline Racer57
« Reply #2 on: June 15, 2016 - 02:06:13 PM »
May sound stupid, but its easy to do......... make sure you do not have the fuel and oil wires mixed up on the back side of gauges.
Offline Rafilla
« Reply #3 on: June 15, 2016 - 05:05:31 PM »
Umm could be work. What can I know the right wires location?? Pics are welcome
Thanks Racer57
Green Go
440
4spd
Offline bc3j
« Reply #4 on: June 16, 2016 - 03:38:40 PM »
I think the wire colors are stamped on the back of the instrument panel. I found this photo on a forum and it was not taken by me. I think it was somewhere on this forum. Apologies to the owner of the photo, which was helpful to me at the time.
« Last Edit: June 16, 2016 - 03:46:42 PM by bc3j »
Offline Rafilla
« Reply #5 on: June 17, 2016 - 02:19:32 AM »
Thank you bc3j. Appreciated!!!
What is the better way (and easy) to take off the gauges??
Green Go
440
4spd
Offline usraptr
« Reply #6 on: June 18, 2016 - 09:39:06 PM »
Rafilla, do a forum search or google search.  There are several threads on it.  First thing you have to do is lower the steering column.  It's been a long time since I did mine but used forum searches to figure it out.  Good luck.
(Edited 8-1-17)
Offline Racer57
« Reply #7 on: June 18, 2016 - 10:21:23 PM »
I suggest you remove the seats so that you can easily look at the back side of the gauges and MAYBE you will get lucky and find places where wires are on the wrong gauge or maybe not hooked up at all. Take LOTS of pics from different angles before you remove any wires.
Offline Rafilla
« Reply #8 on: June 19, 2016 - 06:02:44 AM »
Thank you and apologies the disturb
Green Go
440
4spd
Offline Rafilla
« Reply #9 on: June 19, 2016 - 06:04:27 AM »
Thank you Racer57 appreciated
Green Go
440
4spd
Offline JayBee
« Reply #10 on: June 19, 2016 - 07:28:15 AM »
Found this. It's very brief but gives you the basic idea.
http://www.hamtramck-historical.com/images/serviceHighlights/70%20sh%20148.jpg
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline Rafilla
« Reply #11 on: June 19, 2016 - 08:40:04 AM »
Wow nice pic, thank you very much!!!!
Green Go
440
4spd
Offline lulurocks
« Reply #12 on: June 19, 2016 - 12:34:08 PM »
Might  be able to lay on your back with a shop mirror and check to see if it's wired right
Here's a pic of mine before I removed it:
« Last Edit: June 19, 2016 - 12:41:24 PM by lulurocks »
Offline Rafilla
« Reply #13 on: June 19, 2016 - 03:39:40 PM »
Nice pics lulurocks thank you very much
I need to see in the car the next weekend (if I have time...)
Thanks to all appreciated!!!
Green Go
440
4spd
« Reply #14 on: June 19, 2016 - 05:23:17 PM »
Regulator be stuck on 12vdc instead of pulsing.  If your wiring is ok, you need a new regulator.
