A-833 problems down shifting to 2nd and 1st gear
Author Topic: A-833 problems down shifting to 2nd and 1st gear  (Read 5437 times)
Re: A-833 problems down shifting to 2nd and 1st gear
« Reply #15 on: September 08, 2016 - 06:42:31 PM »
it does list ATF but for Cold climates not warm or racing environments
« Reply #16 on: September 08, 2016 - 08:08:11 PM »
Maybe the bellhousing  is out of alignment? Indicate it?
Offline jimynick
« Reply #17 on: September 08, 2016 - 09:56:31 PM »
OR, learn to rev match/double clutch it upon deceleration.  :2cents:
« Reply #18 on: September 10, 2016 - 07:56:32 AM »
Is that where it comes from? Didn't know that. Back in the 80's, early 90's, everybody I knew with a 833 used ATF4. Using 75/90 or whatever it was worked ok if you shifted slow, like a leisurely drive to work. But if you wanted to get on it, upshift/downshift aggressively, the thicker oil didn't play well with the syncros. Change out to atf4 and slam the gears as hard as you want.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #19 on: September 10, 2016 - 01:44:26 PM »
Heh the guy that rebuilt my A833 said to use ATF explicitly and I have to say after driving Cudas with gear oil and ATF  - I prefer the ATF.
« Reply #20 on: September 10, 2016 - 07:26:23 PM »
Wouldn't draining out the 80/90 and adding ATF mix together what's left and make a goo?
Kinda like what water and oil does in an engine?
« Reply #21 on: September 10, 2016 - 09:22:49 PM »
Redline MT is thinner more like ATF consistancy
Offline HP_Cuda
  • Mopar or No Car!
« Reply #22 on: September 11, 2016 - 02:25:48 PM »
Love that stuff!!!
« Reply #23 on: September 11, 2016 - 09:16:10 PM »
Didn't in my trans. :2cents:
« Reply #24 on: September 11, 2016 - 10:14:46 PM »
Thanks, good to know.
I'm thinking on changing mine out and going to ATF or what CP suggested.
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« Reply #25 on: September 19, 2016 - 01:15:24 PM »
changed the oil from 80W90 GL-4 to MT-90 RED LINE 75W90 GL-4. This did improve the shifting alot. But still some gear noise and hard to down shift 1st and 2nd in speed. 3rd no problem.
Could the problem be the synchronizer slider sleeve (the outer drum) been to worn in the sleeve were the fork pushes it back and forth (1st/2nd gear)? As I was told this was a littel loose by the guy rebuilding the 4-speed.
« Last Edit: September 29, 2016 - 06:10:30 PM by widing'cuda »
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline 72 340
  • Newbie
« Reply #26 on: October 07, 2016 - 02:12:45 PM »
I had experienced the exact same before my 833 rebuild.  The rebuild included a new input shaft.  Now it will go into 1st while moving.  I is really much better to drive now.  My rebuilder showed me the peaks of the teeth on the input shaft gear were worn out and not sharp.
