Author Topic: 70 -71 side mirror interchangable?  (Read 773 times)
Offline culp71
« on: June 16, 2016 - 03:27:01 PM »
would all the internals from a "bullet, sport" 70 mirror fit a 71 "bullet, sport" mirror, I believe everything is the same with the exception of the longer base on a 71.
correct?
glass same size and shape?
also can the cables, at the remote end, be removed, and reinstalled?
« Last Edit: June 16, 2016 - 03:53:24 PM by culp71 »
Offline anlauto
Re: 70 -71 side mirror interchangable?
« Reply #1 on: June 16, 2016 - 04:49:57 PM »
Shape of the mirror glass is totally different which may affect the internals :2cents:
Offline Moparparts
« Reply #2 on: June 17, 2016 - 02:09:07 PM »
I have removed the cables before on originals to have the heads and bases rechromed on restorations but you have to be carefull spreading the white metal crimps that hold them in and sometimes when you bend them back they break. If you are working with a repo i would not attempt it.
